Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 6th November 2012, 02:04 AM   #541
LBHajdu is offline LBHajdu  United States
Are you sure about that? I didn’t read Idss as the maximum current the jfet would pass, because the servo loop could pull the gate connection above ground making it conduct more then Idss. Or is that wrong?
I still support the BL grade though.
Old 6th November 2012, 05:23 AM   #542
ndmrslp is offline ndmrslp  United States
Originally Posted by LBHajdu View Post
LSK170 is also a good option because you are supporting a company who is actually committing to keep it in current production now (they have the same grades).
Do you know where can I buy them?
Old 6th November 2012, 03:31 PM   #543
Loudthud is offline Loudthud  United States
Loudthud's Avatar
I'm sure. The Toshiba data sheet specifies Idss at 10V. It will conduct slightly more, maybe 5%, at 15V and if the Gate-Source voltage goes slightly positive before gate conduction begins. There is also a "V" grade that should work if you can find them.
The operating point of Q4 depends on the threshold of Q1. I'm using an IRF640 which is supposed to use the same die as the IRFF240. I tried an IRF630 and the distortion was lower. I've found the threshold of IRF parts to be remarkably consistant, but Nelson has far more experience with them.
Old 6th November 2012, 06:14 PM   #544
Loudthud's Avatar
That should be IRFP240.
Old 6th November 2012, 08:06 PM   #545
kyuzo is offline kyuzo
if this amp were to be built in a different enclosure how large of a heat sink is necessary?
Old 6th November 2012, 09:59 PM   #546
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
no change needed. The heatsink is sized for the amps heat output, not the case.
If I'm not making noise, I'm making something to make noise
Old 6th November 2012, 10:56 PM   #547
Loudthud's Avatar
In the ACA article Nelson suggests a heat sink of 1 degree C per Watt for each channel. That keeps the temperature rise to about 25 degrees C.
Old 8th November 2012, 06:25 PM   #548
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Amp Camp Amp - ACA
..... how large of a heat sink is necessary?
just dont make it smaller
and notice, its one channel
Old 8th November 2012, 08:13 PM   #549
nr12 is offline nr12  Germany
Just measured: A 0.7 C/W heatsink per channel gives you 47 °C heatsink temperature.
Old 8th November 2012, 08:24 PM   #550
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Amp Camp Amp - ACA
That original Amp Camp chassis as in the photo above, stays very cool since it radiates from lots of thick extrusions in addition to having a quite large heatsink. NP had no hand in its design.
We supply smaller extrusions for the kits (215mm x 75 x 35) those work fine too, in temperate climates and if the amp isn't in an area that's enclosed in any way. My experience is that the micro-climate (is it under a low shelf above?) and actual climate (do you live in southern India? ) are the big determiners. A hot interior room temperature could easily double the amount of cooling needed.
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
