Amp Camp Amp - ACA - Page 54 - diyAudio
Old 4th November 2012, 09:17 AM   #531
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally Posted by nicoch58 View Post
sure ? look there ....
and here : FIRST WATT B1
all info you need
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 4th November 2012, 11:28 AM   #532
Thank You! The B1 on your pictures looks simple. Very fine.
But the B1-PCB & parts-list as offered in the DIY-store looks completely different. So I'm confused.
Where can I buy a simple B1-kit as seen on the photo & firstwatt.com?
I guess, there exists no kit - only a PCB?
Is it the one offerd here: DIY Order Form ???
I should buy the one with 4 matched JFETS and organize all other parts by myself? True?
Old 4th November 2012, 10:15 PM   #533
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
I believe Papa Pass refers to the JFET at the line input on the ACA as a Buffer, so you already have one, albeit simpler. The ACA is actually a pretty complete little amp! I believe that most sources can drive it to clipping so a preamp might not do much. Passive would be the first thing to try.
B1-
Yeah If they are still selling it that B1 board form the PassDIY site is the original and simpler one and getting the included 4 matched JFETS is a huge convenience
Then order the remaining parts from a place like Digi-Key Mouser, Allied.....
The board offered at the store has an integrated shunt power supply instead of a wall wort, relay based input switching, and a place for a volume pot. That's why it looks a bit more complicated
mark
"The geek shall inherit the earth"
2016 S.F. Burning Amp Festival To Be Nov. 13
Burning Amp thread here on diyAudio [/B]
Old 5th November 2012, 12:17 AM   #534
ndmrslp is offline ndmrslp  United States
I read the diyaudio newsletter featuring the amp camp on the same day that my old carver amp decided to stop working yet again. After reading about the event and the amp I've decided that it will be my first diy audio project
My first choice would be to purchase the complete kit, but it is currently sold out. Since I'm without an amp at the moment, I'd prefer not to wait for the kits to restock. To that end I'm putting together a list of everything I need to buy for the project, and of course I have a few noob questions:
1. One item on the parts list (.68 ohm, 3w resistor) is out of stock at Digi-Key and I don't see an obvious replacement or other source for it. Any advice other than waiting?
2. I'm slightly confused by the info for Q4 on the parts list. As mentioned by LBHajdu, I see two versions of the 2SK170 (GRF and BLF) in stock at Mouser, but I don't know which one is correct or if it makes a difference. The article mentions LSK170 as a replacement. Are these available online?
3. Is there a parts list somewhere for non-pcb stuff like wire, switches, binding posts, etc? I see the heat sinks, pcbs and power supplies in the store, but other than that I'm not sure. I suppose those things may be obvious/on-hand to diy veterans
Thanks and sorry for the long first post...
Old 5th November 2012, 05:45 AM   #535
Hi, the customer-service of DIY-store wrote me on October 31 "The Amp Camp Kit will be available in-store very soon. Check back at the store within the next 7 days."
So maybe it makes sense to wait...
Still a question: THESE 5W-AMP CAN DRIVE MY RIPOLS-SUB? For sure it's enough for the OB's, but will there be bass? (I don't want to make "disco", but my listening room has arround 30 squaremeters.)
By the way: Yesterday a friend brought his QUAD II tube-amps along, together with a good preamp. I was amazed how much better it sounds than my MUSICAL FIDELITY A1!!! Much more clearity and the bass was even cleaner.
Old 5th November 2012, 06:12 AM   #536
Zen Mod's Avatar
Originally Posted by merlot5nils View Post
Still a question: THESE 5W-AMP CAN DRIVE MY RIPOLS-SUB........
how can we know that ?
all we know is that you're driving them with A1
Old 5th November 2012, 06:40 AM   #537
diyAudio Editor
Variac's Avatar
It will be more like a month before there are more kits..
Old 5th November 2012, 05:26 PM   #538
bnorrish's Avatar
I was goiing to buy the kit but bought the PCBs and heatsinks as it was sold out. I ordered all the electronic parts from DigiKey and Mouser from the provided build list. What it be possible to list the non-electronic parts as well? Thanks.
Old 5th November 2012, 09:31 PM   #539
LBHajdu is offline LBHajdu  United States
The difference is the IDSS. M.P. says in the B1 project:
The Idss is simply the current that flows through the JFET when the Gate and Source are grounded and +10 volts or so is applied to the Drain. Often when you buy JFETs you can get them in Idss grades. I use GR or BL grades for this project.
The datasheet says:
GR: 2.6~6.5 mA
BL: 6.0~12 mA
I think both would work. In the amp camp project the bias of the jfet is set by the servo loop, R9 and the Vgs of the lower power mosfet. Personally if it was me I would go for BL.
LSK170 is also a good option because you are supporting a company who is actually committing to keep it in current production now (they have the same grades).
Leve
Old 6th November 2012, 12:40 AM   #540
Loudthud's Avatar
You want the BL grade. If Idss is below about 4.5mA, you won't be able to set the quiescent output voltage.
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 40 28th July 2016 08:24 PM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
