#501 |
#502 |
Variac a NP pic on arm ?
Sic58
#503 |
diyAudio Editor
with a halo!
#504 |
I got a second channel up and running. On each channel I installed a 1K resistor from base to emitter of Q3 with a jumper so as to increase bias current to about 2.2 amps. For some reason the DC adjustments of the two channels interact even though separate power supplys were used for each channel. The output caps, C1 are still in place.
For this first test I just used the balanced in and out of the Audio Precision System 1. I'll try other ways of connecting a single ended signal source in a day or two. |
#505 |
diyAudio Editor
Maybe they aren't interacting but there's heat drift?
#506 |
I completed my ACA: Really good. i like it!
It sounds really good and with an adequate level with the cdplayer, with the turntable i need a bit more gain.but there is a little problem: is biased at 10V but is not heating up.. i can keep my hand on heatsinks indefinitely. the heatsinks are hifi2000 model 3PD02200 (200mm*40*80) rated at 0,67c°/w. one channel is a bit warmer than the other one. Is that all right? Thank you! About the t-shirts.. i'll work on the file using forum suggestions tomorrow |
#507 |
I think it was because I was using balanced floating drive. The time constant of C3 is about 4 seconds if the input doesn't have a path to ground. The problem dissappeared when I changed to balanced grounded drive.
#508 |
Been working on these this week after work and finished wiring one up tonight. Seemed ok on a dummy load so I hooked it up and even on one channel sounds sweet. Still need to adjust the voltage, finish wiring up the second mono bloc, finish the cosmetics etc. I will post more thoughts when completed.
Mike |
#509 |
Another view
#510 | |
| Amp Camp Amp #1 | Nelson Pass | diyAudio.com Articles | 27 | 7th December 2012 09:27 PM |
| Amp Camp! | Jason | Site Announcements | 2 | 30th June 2012 02:57 PM |
| Best D camp config for Tweeter amp | Zero One | Class D | 0 | 24th February 2010 04:57 AM |
| better the Pass camp? | rick57 | Tubes / Valves | 6 | 26th March 2005 06:04 AM |
