Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 18th July 2018, 01:30 PM   #4901
bloozestringer is offline bloozestringer  United States
bloozestringer's Avatar
A simple solution.
File Type: jpeg 5EB92715-5E0F-44EE-A301-51F9709EDCC1.jpeg (68.0 KB, 421 views)
Old 18th July 2018, 01:52 PM   #4902
sthcoaster is offline sthcoaster  New Zealand
Amp Camp Amp - ACA
Originally Posted by bloozestringer View Post
A simple solution.
How do you tell the polarity on that thing? Don't want to put it in the wrong way and smoke something.
Old 18th July 2018, 02:09 PM   #4903
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
anyway , fun guaranteed
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 18th July 2018, 05:15 PM   #4904
Mixi is offline Mixi  Europe
A simple solution.
will only work properly if it's gold plated.
Old 18th July 2018, 05:49 PM   #4905
MEPER is offline MEPER  Denmark
Is there a guide included how to use it?
It has to be placed somewhere between left and right "channel" to get an equal mix?
For some it may not be a problem :-)
I could try it tonight…….
Old 18th July 2018, 06:34 PM   #4906
starkeyg is offline starkeyg
Hello, Just wondering which nostril it goes up?
Old 18th July 2018, 06:52 PM   #4907
Zen Mod's Avatar
Amp Camp Amp - ACA
Old 18th July 2018, 07:04 PM   #4908
chrisb is offline chrisb
the one that's not burnt out from snorting coke?
like my mind, this space intentionally blank
Old 19th July 2018, 04:16 AM   #4909
sarathssca is offline sarathssca  India
Originally Posted by sarathssca View Post
Initially i have taken out the separate twisted pair strands from the cat-6 cable and thought to use them independently for each input and output points..
later thought may be if i could use the whole cat-6 cable instead of taking the individual strands out as it looked more protected and secure inside, when used cat-6 cable as a whole.. so as we had 4 pairs available i used used one cat-6 cable for each channel (mono block)..
So shall i take individual twisted pairs from the cat-6 cable outside and twist 4 strands together and out of those 4 strands use 2 for input positive and other 2 for input negative.
And similarly take another 4 strands and twist them together and out of those 4, use 2 strands for output positive and 2 for output negative (so here all will be individual wires without outer protection layers as in whole cat-6 cable)?
I have separated the cat-6 cable outer cover to get the individual strands separated as in photo .. so now one pair of strands for each input positive and negative and output positive and negative .. is it ok now ..
Old 19th July 2018, 07:30 AM   #4910
Alan4411 is offline Alan4411  Wales
Hi sarathssca,
I think this is what everyone is trying to advise you.
You only need a single twisted pair of CAT5/6 wires for each input. (Say white is - and coloured is +)
You need much thicker flexible multi strand wire for the outputs. Use the same gauge / thickness as the blue power wires in your picture. Red and black in my picture.
Keep the input and output wires apart as much as possible.
Hope that helps, Alan
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
