Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 25th October 2012, 08:41 PM   #471
Loudthud is offline Loudthud  United States
Loudthud's Avatar
Originally Posted by janneman View Post
@Loudthud: what was the circuit in the '170 drain lead used for your distortion measurements? Did you measure against earth?
Yes. The 100K input impedance of my Audio Precision System 1 is capacitor coupled. I just left the ground connected and moved the hot lead to different points. To double check, I connected the System 1 differentially across the 1K Drain resistor and there was very little difference in the distortion reading. In the scope photo the output is DC coupled before the output capicitor, the other two traces are AC coupled.
I'm using a linear bench power supply. My shop is about 2 miles from a 50KW AM radio station. At times it gets into things, the analyzer seems to need a ground wire clipped to the circuit under test. There is a 5 Megawatt TV transmitter about 300 yards from the shop, but I never noticed any interference from it despite using a 1 GHz scope.
Old 25th October 2012, 09:20 PM   #472
Loudthud's Avatar
Originally Posted by Antoinel View Post
Loudthud:It seems to me that loop feedback is contaminating the intrinsic performance of Q4 [in janneman's schematic] which maybe pristine without it. What are the distortion properties at the source and drain of Q4 without loop feedback by comparison? How great is the performance of Q4?
Yes, inside the loop distortion can increase quite a bit. The non-linearity of Q1 and it's input capacitance create distortion that the feedback tries to correct. Feeding a square wave to the input you see a couple of hunderd precent overshoot at the Source of Q4 and a great deal more at the Drain. The output looks like an ideal bandwidth limited square wave.
I'll try to plot some meaningfull openloop distortion graphs.
Old 25th October 2012, 09:47 PM   #473
Antoinel is offline Antoinel  United States
Amp Camp Amp - ACA
Thank you Loudthud.
Old 25th October 2012, 09:58 PM   #474
Amp Camp Amp - ACA
A few comments: if you carefully balance the bridged output for equal DC (half supply) there is no longer a need for output caps. If you want to play it safe, a single output cap on one side will do.
The bias current should be increased in the bridged mode of course. You don't get anything for free: quadruple the output power will also mean quadruple the (class A) dissipation and that results from a) double the bias current and b) two amplifiers.
jan
Thank you jan for your comments. I am glad that we agree on the options which can manage the mating of the outputs of 2 ACAs in bridge configuration.
This question posed by DIYers still hangs: Can I bridge 2 ACAs? I am afraid the answer is no for the following reasons:
  • The power supply is undersized.
  • The heat sink is undersized.
  • Doubling the idle bias needs specific modifications from Mr. Pass and/or his appointee.
Maybe others have a different verdict!
Old 25th October 2012, 10:01 PM   #475
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Well the overshoot is not about distortion, it is about gain-bandwidth, a different thing. The real test is to band-limit the square wave to say a 1st order 20kHz, then look at eventual overshoot.
You can always cause overshoot in any feedback amp if you make the rise/fall time high enough, but that's not really saying anything about the performance with music.
The reason for my question above is that I noticed that the distortion on the drain is almost double that on the source, which is curious.
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 25th October 2012, 10:04 PM   #476
jan.didden's Avatar
The power supply is OK, needs no change, if it can supply enough current, or you use one with more current.
Increase heat sink, yes.
The bias current can be increased easily by lowering the 4 resistors that make up the bias sensing from say 0.68 to 0.39 ohms or so.
But I agree, it really becomes a different amp.
Just an idea I had...
jan
Old 25th October 2012, 10:25 PM   #477
Amp Camp Amp - ACA
jan
I agree jan. The DIYer will need a specific set of guidelines and a procedure to transform the current ACA to a bridgeable amp. Maybe Mr. Pass will create an ACA Turbo which can be bridged with no further DIYer modification of its circuit.
Old 25th October 2012, 11:19 PM   #478
Loudthud's Avatar
jan
Voltage at the drain in the split load phase inverter (an analog of the drain current) depends on the total impedance at the source which includes the gate of Q1 and it's gate stopper. The point of the overshoot being that Q1 is a substantial load. I tried the ACA using IRFP460's which have a Ciss over 4000pF. The results were terrible even with 3 Q4's in parallel and R9 at 330 ohms. Obvious distortion on high amplitude outputs even at 1kHz. The non-linearity of the capacitance was evident when Q1's drain voltage dips below it's gate voltage.
Old 25th October 2012, 11:30 PM   #479
Loudthud's Avatar
Getting the analyer to plot distortion vs generator amplitude was not straight forward, it likes to plot against the analyzer amplitude. I think I got it right, but the graphs have some surprises. Q4's drain voltage is plotted single ended to ground and differentially across the 1K resistor. I didn't install the decoupling network that Jan used, but there is a 100uF cap bypassing the 19V right near Q4.
Old 25th October 2012, 11:49 PM   #480
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
measure bridged ACA
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
