Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 21st June 2018, 11:39 PM   #4691
Extreme_Boky is offline Extreme_Boky
Originally Posted by Soundhappy View Post
I do have similar experience with Diy M2 amp gain=15dB.
Your ACA is the first 14 dB version no doubt.
I can use passive AVC , audio source = 2V without active preamplifier.
My speakers are 98 dB efficiency.
With less efficient speakers 88 dB I do need active preamp imho.
New ACA 1.5 have only 10 dB of gain....
Anyway BA-3 is not constipated by the feedback loop
R12 is around 68K on the latest diagram; 39.2K on the original diagram. New ACA can only have more gain, not less...
Old 21st June 2018, 11:58 PM   #4692
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
How much of dB ?
You can verify by youself on the left ACA V1.0 on the right side new ACA 1.6
source : http://www.firstwatt.com/pdf/art_amp_camp_1.pdf
File Type: jpg 82483F50-5910-4736-A4AF-879FA77E11DF.JPG (551.2 KB, 386 views)
File Type: jpg 8E3C1173-A589-4AD0-B21C-471464E9AF4C.JPG (306.4 KB, 385 views)
class A amplifiers with full range speakers
sings like angels in heaven
Old 22nd June 2018, 01:31 AM   #4693
ThermalAlchemy is offline ThermalAlchemy  United States
Default Help with choosing subwoofer amplifier to companion ACA
Like a child on Christmas morning just received one of my two chassis go to ACA 1.6 sitting on top of my original amp camp amp chassis I modified from a old mini computer chassis and just attached heat sinks to that side of it.
Been using the Krong tube as a preamplifier along with comparison the DarkVoice 336 SE and IFI micro Black Label as preamp.
It appears if you wanted to you could mount the Krong PCB inside the chassis of the amp camp amp.
Even the original Amp Camp Amp 1b PCB pictured below is more than enough power then you can comfortably listen to with the BK-20 Fostex speaker cabinet kit using them Fostex FE206En drivers. I will use my original ACA 1b. To drive the tweeters Fostex T90A ( that’s just for the family members who can hear both 15K+ , my hearing starts rolling off at 12k and stone cold death after 15K.) and the new 1.6v ACA to drive the Fostex FE206En Full range. Now just need to build a amp for the subs.
Somebody with experience any recommendations for a subwoofer amplifier, maybe (Honey badger, F5 or F6 Turbo?.) For now will be driving two 12 inch subs.
File Type: jpg 19F68046-0778-4069-B2FD-685D79786E0E.jpg (638.0 KB, 378 views)
File Type: jpg E13317DD-6D6E-4EBD-A464-FBF8D024300E.jpg (639.5 KB, 371 views)
Old 23rd June 2018, 09:05 AM   #4694
Spencer Brandsen is offline Spencer Brandsen  Netherlands
'It appears if you wanted to you could mount the Krong PCB inside the chassis of the amp camp amp.'
Yes, I want that. But what's a Krong tube preamp?
Old 23rd June 2018, 09:29 AM   #4695
MEPER is offline MEPER  Denmark
It looks like a Korg Nutube:
Nutube – English | korgnutube.com – English
Old 23rd June 2018, 10:06 AM   #4696
Thanks, MEPER, you're right. It's a hybrid headphone amp with Korg Nutube. Did anyone try a preamp with Nutube in front of an ACA?
Old 23rd June 2018, 10:18 AM   #4697
twocents is offline twocents  South Africa
twocents's Avatar
It was probably the B1 using the Korg Triode referred to here, as this B1 has some gain. See post Amp Camp Amp - ACA - it looks like a kit is on the distant horizon.
I am currently running my ACA with a B1, but found (like others here) that the ACA really shines with an active preamp. I think this B1 with the Korg could make a great pre for the ACA, and would be great if someone can report on how well they pair.
PS: Spencer - sorry, my post was shortly after yours - I did not see that.
I also see now that ThermalAlchemy's preamp is a Pete Millet Korg preamp. Wonder how that drives the ACA?
Old 23rd June 2018, 12:07 PM   #4698
Sorry (Korg NuTube) I was driving and using voice to text when I made post. Definitely Get the tube sound. I only get it ringing if you tap on the case.
Old 23rd June 2018, 12:32 PM   #4699
In that case: don't tap on the case.
Old 24th June 2018, 06:59 AM   #4700
irishpatrick33 is offline irishpatrick33  United States
Everything I have read suggests the Millet Nutube preamp is incredibly microphonic. Makes me wonder whether Millet got an early batch that happened to be microphonic. Or are the Nutubes inherently microphonic?
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
