Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 21st June 2018, 11:36 AM   #4671
Spencer Brandsen is offline Spencer Brandsen  Netherlands
I have an ACA 1.3 here at the moment with only a 'dumb pot' in front of it. Sounds okay. So why do people say it's not a good solution? How much better will it sound with a B1 buffer or an active preamp?
Old 21st June 2018, 12:05 PM   #4672
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
try, and let your ears decide , not mine or anyone else's
I did some writing regarding that , mostly in What's wrong with the kiss,boy ? and Iron Pumpkin(s) and other smaller vegetable animals threads
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 21st June 2018, 12:06 PM   #4673
MEPER is offline MEPER  Denmark
The ACA is the first amp I have tried where an active pre-amp made a relative big improvement compared with a passive pre-amp. It probably has something to do with the construction. When you add a serie resistor (pot) you change the amount of NFB. But yes....it sounds ok with passive pre-amp but more silky treble (not as hard) and better defined bass using an active pre-amp. At least that was my conclusion after trying both.
Old 21st June 2018, 12:11 PM   #4674
rnjorge is offline rnjorge  Brazil
This weekend I built the B1 to test it against Schiit Audio Saga (passive preamp).
The result: "WOW! How could I live without it for so long? "
And this without any fancy parts, just what I had at home.
But do as Zen Mod says and try it for yourself.
Old 21st June 2018, 02:56 PM   #4675
I struggled through 25 pages of posts before I gave up.. I understand that a certain preamp (of which I don't know what it is) gives more and better bass. And that I will probably need an active preamp to get the best out of an ACA (more silky treble and better defined bass). But what active preamp?
Old 21st June 2018, 03:05 PM   #4676
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Originally Posted by Spencer Brandsen View Post
....But what active preamp?
Line stage ( non phono ) active preamplifier without feedback example :
The BA-3 as preamp build guide
Enjoy
class A amplifiers with full range speakers
sings like angels in heaven
Old 21st June 2018, 03:39 PM   #4677
johnnycamp5 is offline johnnycamp5  United States
I agree with this.
I am building a DIY preamp “kit” for this purpose called the “Forewatt” .
Meper- how much negative feedback does the ACA have...three or four DB?
I was under the impression this circuit had 0 NFB.
Old 21st June 2018, 04:39 PM   #4678
Originally Posted by johnnycamp5 View Post
I agree with this.
The NFB resistors are R11 (10k) and R12 (39.2k). So if you have 5 V out then approx. 1 V will be returned to the input. R11 and R12 are the dividers for the NFB.
NFB is an integrated part of the ACA design. It would nok work very good without NFB. I think bass control would be bad and response not very linear. Nelson Pass has open loop curves at FirstWatt pages for the ACA.
The first ACA version had less NFB. You can play with the amount of NFB to find out the difference in sound. Gain will be higher if you have less NFB and damping factor lower.
Old 21st June 2018, 04:57 PM   #4679
Thanks. The BA-3 looks like something I could use. But I suppose I can't buy it as a kit with a good manual?
Old 21st June 2018, 05:34 PM   #4680
ernesternest is offline ernesternest  Europe
ernesternest's Avatar
Doesn't have BA-3 pre part have enough oomph to drive F4? This would be way too much for ACA. Use something with about 3x voltage amplification. It does sound pretty good with simple tube Pre, with Salas HPA used as a Pre. Whammy works.... One of Juma pre's. Lots of options for really good sound. There is not the one preamp for ACA.
Cheers, Ernst
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
