Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 12th April 2018, 09:50 PM   #4071
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
it's always softer , when on side with lesser current change
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th April 2018, 01:25 AM   #4072
clowkoy is offline clowkoy
Originally Posted by Soundhappy View Post
Anybody experiment what is SMPS difference between power on-off at DC side
and probably much less thumb noise into speakers if the switch power on-off position is at the 110/ 230V AC side ?
Cheers
No noise on mine with switch on AC side but I added a CL-140 thermistor in series. There is also a 33k uf cap in parallel with the DC output. I removed the resistor/diode combo because it still produced the turn on “fart”.
Old 13th April 2018, 01:45 AM   #4073
tjw59 is online now tjw59  United States
Default Thanks 6L6
Great - Thanks!
Old 13th April 2018, 02:52 AM   #4074
chrisb is online now chrisb
So, stand upwind when firing up?
like my mind, this space intentionally blank
Old 13th April 2018, 12:15 PM   #4075
Thanks!
Old 15th April 2018, 03:11 PM   #4076
bloozestringer is offline bloozestringer  United States
bloozestringer's Avatar
I think I’m going to build a B1 for my ACA’s as I finally have time to build the amps. Is there any reason I couldn’t have the power for the B1 supply power to the monoblocks through umbilicals? Reason I ask is I really don’t need three more units to try and find outlets for in an already cramped space. Also, would it be worth it to go ahead and run off 24v?
Old 15th April 2018, 03:37 PM   #4077
6L6 is offline 6L6  United States
6L6's Avatar
Amp Camp Amp - ACA
Yes, you could daisy-chain the power through the B1.
24v for the amp is worth it.
Here's a possible solution for your outlet issue -
Old 15th April 2018, 03:51 PM   #4078
Yeah, have one or two of those. Turntable, three headphone amps, CDP, music streamer, two tube amps, and receiver so far in a 11x11 foot room that shares an office desk and guitar gear. Looks like Im starting a cable supply company behind the rack
Old 16th April 2018, 09:11 AM   #4079
3kes is offline 3kes  Netherlands
Newbie question: I want to make a linear PSU for the ACA. What is the max DC that the board can handle?
Old 17th April 2018, 04:22 PM   #4080
coolnose is offline coolnose  Europe
coolnose's Avatar
Limited mainly by j-fet dissipation I would say. Voltage limited as well to more or less 32V for the 2sk170 (lsk170 I am not sure...) as well as per NP advice (see F5 turbo article).
After that comes heatsinking the output transistors.... and in the end comes the bigger hammer approach of ZM...
EDIT: Stay with 24v (or so) or build something else - unless someone here want's to chime in to complicate a simple project
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
