Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 3rd January 2018, 01:57 AM   #3661
moppy is offline moppy  Malaysia
Originally Posted by Zen Mod View Post
-yup
-almost yup - for R14 use at least regular metal film , which is 600mW ; smaller will do , but peak power (with 24Vdc supply) would be in vicinity of 600mW
all referring to schm published in first Amp Camp Amp pdf
I have ordered Vishay RN60 Series B14 Axial Metal Film . I ordered this from RS component. When I ordered it wrote 0.25w but when I received it the packaged wrote 0.125w.
Moppy
Old 3rd January 2018, 02:01 AM   #3662
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
for R14 use whatever you have in drawer , from 470R to 4K7
it's easy to calculate peak power through it ;
presume 24Vdc supply , peak current is then I=24V/R
power is P=U x I
that's "just" bleeder resistor , there to prevent output cap having floated output side , so no POP! while you're connecting speaker wires
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 4th January 2018, 03:02 AM   #3663
power is P=U x I
Ok will bear in mind.
I'm building another set of ACA, like you said using 24Vdc, that means the Vac transformer is 18v, rite?
Moppy
Old 4th January 2018, 03:19 AM   #3664
Zen Mod's Avatar
Amp Camp Amp - ACA
rule of thumb , with heavy loads as A class amp is , you're getting Vdc ~ 1.25 x Vac , when using (most common) cap filters
Old 4th January 2018, 04:31 AM   #3665
So is about 20v...
Moppy
Old 4th January 2018, 06:04 AM   #3666
Zen Mod's Avatar
Amp Camp Amp - ACA
it seems we're having different calculators
Old 4th January 2018, 10:12 AM   #3667
1.25 x 20v... no?
Moppy
Old 4th January 2018, 10:34 AM   #3668
Zen Mod's Avatar
Amp Camp Amp - ACA
18 x 1.25=22V5
again , that's approximately
Old 11th January 2018, 11:39 PM   #3669
zekeblue is offline zekeblue
Anyone know what happens with the ACA power if feeding 16ohm speakers rather than 8ohm?
I built the kits onto 24v toroid power supplies.
Thanks!
Old 12th January 2018, 12:58 AM   #3670
Zen Mod's Avatar
Amp Camp Amp - ACA
approx. 3 clean watts , with 24Vdc rail
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
