Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 7th December 2017, 02:20 AM   #3581
Skylar88 is offline Skylar88  South Africa
Default IRFP250 for ACA
Just noticed that the IRFP240 is not available anymore, but I can get Vishay IRFP250. Can that be considered a straight replacement for my ACA V1.1 build?
Old 7th December 2017, 03:48 AM   #3582
Loudthud is offline Loudthud  United States
Loudthud's Avatar
The extra input capacitance of a 50 series MOSFET will cause an increase in distortion at high frequencies. I tried a 60 series MOSFET and you could see the distortion on a scope at 1KHz.
Old 7th December 2017, 04:01 AM   #3583
Eslheadphone is offline Eslheadphone  United States
I would use bipolar transistor in the capacitance multiplier as the voltage drop will be about 4 volts. I used a capacitance multiplier in my F5 as the power transformer I had on hand was 20 volts instead of 18 volts and it worked out quite nicely.
Old 7th December 2017, 05:47 AM   #3584
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
1) IRFP240pbf is still certainly available.
2) If you go with bipolars best to assemble Darlington.
3) You don't need the 47000uF but keeping the 4700uF at the output would be ok.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 7th December 2017, 08:02 AM   #3585
Thanks for the replies. You guys are great.
4V drop is exactly what I'm hoping for, and I'll put the 4700uF back into my schematic.
The RS website (where I get most of the components from) says the IRFP240 has been discontinued. I assumed nobody else will have it either, but now I'll check.
Old 7th December 2017, 08:20 AM   #3586
Search irfp240pbf
Old 7th December 2017, 10:27 AM   #3587
Thanks, I found some IRFP240's at another local supplier. They have limited stock.
How would I know if it's original Vishay FET's? I've asked and the letters following 240 is Y7IK, not PBF.
A mate mentioned the IRFP244. Would that work if stock on the 240 runs out?
Old 7th December 2017, 10:51 AM   #3588
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
nobody is faking them
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 7th December 2017, 12:23 PM   #3589
Thanks. That's good to know.
Old 7th December 2017, 09:32 PM   #3590
IRFP240PBF Vishay Siliconix | Discrete Semiconductor Products | DigiKey
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
