Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 10th November 2017, 05:37 PM   #3511
kwolff67 is offline kwolff67  United States
Knowing nothing about heatsinks, I wondered if I could trouble someone to let me know if this spec is ok for the ACA. Length I ordered is 10" (Qty2). This width was like $.30 per inch cheaper than some others close to this size, and now I'm afraid I might have gotten it wrong.
I still don't understand the c/w rating.
Extruded Aluminum Heatsink
Alloy: 6063-T5
Width: 4.850"
Fin Height: .66"
Base: .140"
C/W/3": approximately 2.25
Weight per Inch: .13
Old 10th November 2017, 06:01 PM   #3512
wrath is offline wrath  Poland
Base: .140"
If you push 1 watt into that radiator temperature will rise 2.25 celsius
Old 10th November 2017, 06:14 PM   #3513
Thank you.
So pushing a maximum of 7 watts the temperature would be close to 16c or 60F. That sounds like it should be fine and never go hotter than room temperature unless I'm missing something. Or do I need to factor in ambient temperature as well?
Old 10th November 2017, 07:26 PM   #3514
Gregje is offline Gregje  United Kingdom
Thank you.
It will be 16c warmer than your room
Old 10th November 2017, 08:07 PM   #3515
Ok, that's too hot. I need the amp to be on most of the day, and have 2 dogs and a cat, all with a curious nature.
I canceled the order and will get something larger with at least 1inch fins.
Thanks.
Old 11th November 2017, 08:50 AM   #3516
6 watt aca push into speaker. Into heatsink more like 12....
Old 11th November 2017, 05:59 PM   #3517
pinholer is offline pinholer  Canada
The thermal coefficient of 2.25 C/W is for a 3" long piece so a 10" piece will have better performance.
Old 12th November 2017, 12:32 AM   #3518
I think this will work better. It has 1 inch fins and a much thicker base and a c/w of 1.15. Same 10inch length or maybe 12.
Alloy: 6063-T5
Width: 5.375"
Fin Height: 1"
Base: .375"
C/W/3": approximately 1.15
Weight per Inch: .37
Old 12th November 2017, 07:31 PM   #3519
PCBs and Keratherm pads ordered from DIYAudio store.
LSK170 ordered from NAC.
The rest from Digikey.
Just one thing I'd like to confirm:
LSK170A TO92 - This is the correct JFet for Q4, right?
Old 12th November 2017, 07:43 PM   #3520
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
more 170B
though , there is already asked and replied same question and solution
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
