Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 17th February 2017, 11:00 PM   #3171
HemiBooch is offline HemiBooch
rnjorge: Yes - swapped PSUs and have eliminated many other variables as well, e.g. tried different preamps, different sources, etc.
Old 17th February 2017, 11:07 PM   #3172
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
Originally Posted by HemiBooch View Post
DIY friends. Finally had an opportunity to take and post some photos of my wayward 1st attempts at building amps.
So, first, 4 photos of the good one.
Then, 4 photos of the bad one.
The ugly? Well, one look at my soldering...
Thanks for any and all sleuthing to help this rookie DIYer...
I must confess, about ready to throw in the towel
good one is good by sheer luck
bad one is bad most likely because of bad soldering , all over the place
remove pcb from htsnk , inspect and redo ............ everything
if your solder iron is too weak , find more powerful one
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 17th February 2017, 11:11 PM   #3173
OK - what do I look for to ensure a proper solder iron?
Old 17th February 2017, 11:42 PM   #3174
Zen Mod's Avatar
Amp Camp Amp - ACA
well , plenty of tutorials on ootoobe , much more informative than I could write here
I believe you can find cheap soldering station in power range of 50W and do everything what amateur needs
after decades of using cheapest ones , same as pro range , now I'm having two of these on my bench
I need big bada$$ 60W only for crudest speaker terminals
also - it pays off finding some old pcb (old TV or PC Monitor or whatever , and have some fun desoldering and soldering
Old 18th February 2017, 12:10 AM   #3175
OK - thanks guys. Looks like my soldering needs a lot of practice and a better tool for the job. You are all gracious and helpful, and most appreciated.
Old 18th February 2017, 03:23 AM   #3176
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Amp Camp Amp - ACA
Seems like you could reheat each joint a bit hotter, maybe you were afraid to overheat stuff. And if the solder doesn't flow then get some flux and paint it on the joint and reheat. Make sure there are no shorts, I see some wire strands close to each other..
My initial trouble shooting routine:
- make sure resistors are correct values- esp. the ones with or without K in the value.
-Make sure caps are inserted with the plus lead in the correct hole
-Make sure the tiny transistors are in the right places.
-reheat each joint until it flows better, sometime feeding in a bit more solder to add flux.
-check no "whiskers " of solder or strands of wire are shorting something out..
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 18th February 2017, 04:45 AM   #3177
koja is offline koja  Canada
as a suggestion: the ACA kit should offer the DPST version of the same switch so one can optionally implement a relay on the speaker output to reduce the turn off thump. I just did it and I had to break the original switches as I could not pry them out of the front plate. just saying...
Old 18th February 2017, 04:52 PM   #3178
Default Re-soldering in my future...
Thanks Variac:
Will re-do everything and hopefully my skills are good enough to now to make this thing sing!
Old 19th February 2017, 04:25 AM   #3179
kpsthakur is offline kpsthakur  India
Also please test your MOSFET's...n good luck
Sent from my iPhone using Tapatalk Pro
Old 20th February 2017, 03:30 AM   #3180
ZacharyP is offline ZacharyP  United States
Initially I planned to build a b1 buffer, but I'm not sure if 2vrms is enough to drive both channels of the ACA to clipping. This leads me in search of a low-gain preamp that I can use with my ACA.
Any recommendations or thoughts?
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
