Amp Camp Amp - ACA - Page 26 - diyAudio
Old 4th August 2012, 11:22 PM   #251
Old 5th August 2012, 01:13 AM   #252
Variac is online now Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Well exactly, How can you re-create the awesomeness of the original event without the original boards? Duh!
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio
Old 6th August 2012, 07:02 PM   #253
6sigma is offline 6sigma  United States
Eager to buy a pair of these amp kits, what "site/store" must I visit to place an order?
Thanks.
Old 7th August 2012, 12:28 AM   #254
zany is offline zany  Australia
the navigation bar at the top has a store link... they will be available in the next few weeks as per Variac's message earlier.
Old 7th August 2012, 01:56 AM   #255
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
Has anyone tried bridging a pair of ACAs?
Old 9th August 2012, 02:07 AM   #256
Loudthud's Avatar
I haven't tried bridge mode yet, but I built a second channel with IRFP460s. Seems like the distortion is lower but my AP System 1 is on the fritz. I did notice that the DC level control does not track the power supply. It keeps the level the same as the supply goes from 20 to 30V. I plan to try a P-channel JFET (or PNP transistor) on the input like knutn tried on the PLH: NOStalgia - the all-FET JLH/PLH Class A amplifier
Old 9th August 2012, 11:05 AM   #257
Please see thread #632 in the topic F6 amplifier for ideas.
Old 9th August 2012, 07:56 PM   #258
LBHajdu is offline LBHajdu  United States
I plan to try a P-channel JFET (or PNP transistor) on the input like knutn tried on the PLH.
This is to be expected. The DC servo on this amp works like the Vbe bias transistor on a regular follower amp. That is to say P1 makesa resistive divider between output and ground. The middle point is referenced to the gate of Q1. At start-up the bottom mosfet is not conducting, but the current source (top mosfet) will start flowing down current. This will cause the output before the dc blocking cap to rise. When it rises high enough it will cause Q4 and in turn Q1 to conduct bringing the voltage down, because P1 takes the before DC blocking output voltage divides it by some percent and delivers it to the gate of Q4. When it starts to conduct is determined by where P1 is set and the Vgs threshold voltages of Q4 and Q1 summed. Increasing the rail voltage has no effect, you have to readjust.
Mr. Pass told me about calculating output impedance so I am in turn passing what I know…
You can’t simply plug a P-channel JFET . I did propose a modification that would let you use a P-channel jfet here:
Originally Posted by LBHajdu View Post
This would change the feedback to source feedback. The whole amp topology changes to non-inverting. It seems ok in simulation. Such an amp would more or less adjust to rail voltage changes, but again it is a totally different amp. The schematic looking similar is a trick of the eye. Note the jfet has changed from N to P type and it has been flipped with the drain now pointing to Q1 instead of the source. It might be better to use a pot here to adjust the before dc offset to (v+)/2 .
I am also curious about J175 in a source feedback type topology, because it can be used to drive power JFETs which cannot be simply dropped into the current amp camp.
Old 9th August 2012, 09:11 PM   #259
Loudthud's Avatar
The topology I use is much like the original single rail JLH were emitter (or source) current for the input transistor (I call Q5) comes from the feedback loop. The problem is that the impedance at the gate of Q1 needs to be low and that requires lots of current, 5 to 10mA. To lower the impedance of the feedback loop requires a bigger than I would like capacitor in the ground leg of the feedback network. So I was going to keep Q4 in the circuit with a resistor of maybe 10K to ground on the gate and drive that with about 300uA from the added input device Q5.
I built an amp with the input device Q5 driving the MOSFET Q1 directly. I had to add a current source from the positive rail (much like later JLH versions) to keep the feedback loop impedance up. Results were mixed. I tried making a dual rail version but that is problematic without a diff pair on the input. I want to keep things simple with a single ended input stage.
Old 9th August 2012, 09:20 PM   #260
Loudthud's Avatar
I did try driving a 4 ohm load. The stock ACA is a little weak and distortion is higher. I increased the current by adding one additional resistor in parallel R1/R2 and R3/R4. That got the distortion back to where the stock version measures with an 8 ohm load. Naturally the heat sink got hotter. If you are satisified with 5 watts, reduce the supply to 13V and the dissipation is about the same.
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 43 24th October 2016 04:09 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
Copyright ©1999-2017 diyAudio
