Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 21st July 2012, 10:39 PM   #201
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Amp Camp Amp - ACA
Not inverting if you hook it up as laid out....
Old 21st July 2012, 10:54 PM   #202
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Amp Camp Amp - ACA
ehh, because input ground resistor connects to -out, I guess
but with +out connected to ground/chassis, strange thing
ehh, input cap C3 is also a polar electrolytic cap
well, it is according to parts number
Old 21st July 2012, 11:11 PM   #203
The one and only
Amp Camp Amp - ACA
Picky Picky....
It's a silk electrolytic. Measures and sounds better than a
lot of film caps.
And you can't get a tube or a transistor to give you voltage gain and
not have inversion somewhere unless you introduce the dreaded
transformer. Non-inverting amplifiers with voltage gain simply find
some way to flip the phase an even number of times. In this amp,
the second time is at the output terminals.
Old 21st July 2012, 11:18 PM   #204
Amp Camp Amp - ACA
my brain says bedtime
thanks Nelson
Old 22nd July 2012, 02:54 AM   #205
The one and only
Amp Camp Amp - ACA
I made an error - of course you can get voltage gain without inversion,
simply use Common-Base operation.
Doh!
Old 22nd July 2012, 11:22 AM   #206
Amp Camp Amp - ACA
Doh!
its ok, noones perfect
I suppose using matched outputs are more or less standard now ?
Old 22nd July 2012, 12:33 PM   #207
flg is offline flg  United States
flg's Avatar
The mu follower has a relatively high DC impedance, but it is an active
component with an AC negative resistance. It contributes to raising the
apparent output impedance of the amplifier.
I am confused by these statements
If it is "an active component with an AC negative resistance" how can it's contibution be higher impeadance? It's negative, simply speaking, thats lower.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 22nd July 2012, 01:24 PM   #208
Antoinel is offline Antoinel  United States
Amp Camp Amp - ACA
Picky Picky....
lot of film caps.
Silk is a protein and a poor conductor of electricity; albeit polar [compared to polypropylene], and thus polarizable [via voltage]. It has amino acids in its primary polymeric structure which do not have extra [basic] amine and [acid] carboxylic groups. These groups react chemically with each other to generate zwitter ions [intra acid-base neutralization] to make the ionic ammonium carboxylate. These ions are electrical dipoles which will cause the dreaded dielectric absorption [of acoustic energy] which reverts them to the un-neutralized parent. Silk is a great eco-dielectric for high quality electrolytic capacitors.
Old 22nd July 2012, 01:27 PM   #209
stefanobilliani is offline stefanobilliani  Italy
Old 22nd July 2012, 01:34 PM   #210
Amp Camp Amp - ACA
Of additional interest is an answer/explanation for the amplifier without loop feedback, driven by one complete sinusoidal signal into a load of 8 Ohms. What is its output impedance it experiences along the signal trajectory? Is is a constant 10 Ohms like in the quiescent mode?
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
