Amp Camp Amp - ACA - Page 172 - diyAudio
Old 13th February 2014, 06:03 PM   #1711
toobhed is offline toobhed  United States
The two problems that I faced was the PSU jack whose two tabs I soldered were the wrong two of three tabs....after resoldering different tabs it worked great.
The other problem I had on the second monoblock was that the RCA input was shorting due to melted insulation....once I fixed that everything was fine...hope this helps a bit.
Old 13th February 2014, 08:02 PM   #1712
When I first built the ACA the PSU socket was the bit that caused me the most stress. The original build thread picture wasn't great and wiring the different legs was a matter of educated guess work. The picture is better now.
Even after that 6L6 and I exchanged about 13 emails and several pictures of my ACA trying to figure out why it kept blowing my PSUs.
It turned out that one of the legs on the PSU socket was loose and would rotate round when the case was knocked. The supply would short and bam. I went through 3 PSUs before we sorted it.
Old 13th February 2014, 10:52 PM   #1713
Sorry if this has been asked before but I searched and could not find my answer. I just purchased the PCBs since the kit is sold out and before I place my digikey order for parts I'd like to source the 2SK170. Which grade (gain??) should I be looking for? And do I need a matched pair? Or is that just for push/pull or other applications with multiple 2sk170s per channel.
Old 13th February 2014, 11:30 PM   #1714
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
no matched
2SK170BL is most adequate
if going to DiyA Store LSK - take LSK170B , preferable , being same current (6-12mA ) grade
or just take anything they have
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 14th February 2014, 07:12 AM   #1715
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Here is what Papa Pass told me a while ago:
By the usual standards the D version would be the most desirable, and probably would command a premium. The B through D and most of the A would not be a problem for the ACA, and a slight adjustment would allow down to the 2.5 mA figure without problems.
Most of my projects would want a B or C grade as most desirable, but it’s not a big deal.
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio [/B]
Old 14th February 2014, 03:32 PM   #1716
Awesome thanks guys, I'll see if anyone in the buy/sell forum has a few to sell. Don't need the big lot that store sells.
Old 14th February 2014, 03:50 PM   #1717
Zen Mod's Avatar
if you start with anything here , soon you'll search for more
Old 14th February 2014, 03:52 PM   #1718
sandyhooker's Avatar
Default guesstamate
How about j310 for a starter in this circuit??!!
Old 14th February 2014, 06:19 PM   #1719
diyAudio Editor
Variac's Avatar
Huge lot of JFETS coming to the diyAudio store.
Old 14th February 2014, 06:38 PM   #1720
Zen Mod's Avatar
309 or 310
sort proper source resistor to have no more than 10mA though Jfet and proper biasing of output mos
edit - it seems proper starting value for J310's Rs is in range of 680R
start biasing with bias pot's wiper cranked to zero
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 43 24th October 2016 04:09 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
Copyright ©1999-2017 diyAudio
