Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 12th September 2013, 01:27 PM   #1321
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Originally Posted by 51frankie View Post
So those of you who have built and use the ACA, what speakers work well and how to you do a volume control?
Something like Lowther PM6A + 15" bass or an Audio Nirvana 15" Full Range driver are extremely good speakers for this amp. Either of these drivers in an open baffle setup, and if you have a small room don't be concerned about that, just keep the baffles moderately sized.
Open baffle all the way.
Old 12th September 2013, 03:35 PM   #1322
Loudthud is offline Loudthud  United States
Loudthud's Avatar
@all212
Your readings (as corrected):
C1 + = 10
C1 - = 0
Q1s = 0
Q1d = 10.1
Q1g = 4.5
Q2s = 10.7
Q2d = 19
Q2g = 15.3
C4+ = 19
C4- = 0
Q4d = 19
Q4g= 4
Q4s= 4.5
C3+ =4
C3-=0
Q3e=10.1
Q3b=10.7
Q3c=15.3
Those voltages all look correct to me. It seems to me that there is some kind of fault in the ground. Check all ground points with an ohm meter (power off, inputs disconnected) and check for any voltage difference between ground points (power on).
Old 12th September 2013, 03:38 PM   #1323
12B4A is offline 12B4A  United States
12B4A's Avatar
On each of the ACAs I built, I had to rub some of the anodization off at the corners where the heat sink mounts in order to get the entire chassis grounded.
Old 12th September 2013, 04:55 PM   #1324
JP14 is offline JP14
Originally Posted by 2 picoDumbs View Post
It's very easy to learn how to drill and tap holes. I understand you may not want to go down that road though
While that's true, I don't have a drill, and wasn't planning to purchase one to put this kit together. Still waiting for the diyAudio folks to reply.
Old 12th September 2013, 09:19 PM   #1325
Have you sent Variac, Jason, or The Store a message?
Old 12th September 2013, 09:32 PM   #1326
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Amp Camp Amp - ACA
Originally Posted by JP14 View Post
.... Because heat rises, that means that every other part on the board gets the heat from the mosfets.
My thinking is that if I put the mosfets at the top, the capacitors would get the cool air coming underneath and therefore operate at a lower temperature.
no, it is classA and everything gets hot
but you still lower efficiency of your heatsink that way
you should not mount your out devices at top of heatsink
sometimes we know very little, and sometimes we know too much
Old 12th September 2013, 09:33 PM   #1327
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
Amp Camp Amp - ACA
DIY Audio - I'm working on the ACA kit that I recently received and just noticed that the screw holes on one of my heat sinks are off.
Yes, definitely looks like the heatsink was offset incorrectly during drilling. Please contact diyAudio store support and they'll arrange a replacement for you.
Please direct all private requests for diyAudio store support here: Contact Us or public requests here: The diyAudio Store - diyAudio - store support doesn't watch the threads in the main forums - sorry!
Old 12th September 2013, 11:20 PM   #1328
all212 is offline all212  United States
@LoudThud and 12B4A
Thanks for help!
I used a slightly better grade input RCA that I had laying around and it has two plastic washers on the inside of the chassis - I managed to get the grounding lug for the RCA in between these and perfectly centered and it was making no contact with the RCA body.
Put the grounding lug on the outside of the washers next to the nut and watdayano - no more humming.
Gratuitous pictures...
With Bottlehead Quickie Pre:
They are not powering the DQ's! Look for the small mini's resting on the inside of the DQ's. Dq's will get some of this but they are horribly power hungry.
Very nice sound!
Old 13th September 2013, 12:03 AM   #1329
billyk is offline billyk  United States
billyk's Avatar
Originally Posted by all212 View Post
@LoudThud and 12B4A
Thanks for help!
Very nice sound!
Dang, sure looks sweet! Don't ya just love this stuff!!!
Old 13th September 2013, 08:27 AM   #1330
Jason's Avatar
Amp Camp Amp - ACA
Originally Posted by WalterW View Post
Hi, does anybody know what the Digikey partnumber is for the red rockerswitches for the ACA chassis?
Or the manufacturer and model?
My chassis arrived in Holland, I can pick them up tomorrow
There were some photos with red rocker switches. Andrea and I just bought them from a local electronics shop. I think they looked really great with the red chassis personally, but we'd already bought the parts for the kits and the power switches come with the kits not the chassis.
I think changing the switch is a nice way to personalize the design a bit and it would be great to build a list of possible switch alternatives people can order to trick up their chassis.
The power switch that comes with the kit is Digikey 401-1303-ND (Invalid Request). I imagine at a guess anything the same dimension should work, including the colorful 401-1307-ND (Invalid Request), but don't quote me on that
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
