It seems that one of you full range drivers should be rolled off lower than the other to avoid comb filtering etc. Probably you are- to counteract the rising response they tend to have..
Latest OB prototype in celebration of ACA. I will be testing all my ideas on this one.
Let the celebrations begin.
Correct. The funny thing is, even with the rising response, they don't sound very detailed. That's why I added the horn.It seems that one of you full range drivers should be rolled off lower than the other to avoid comb filtering etc. Probably you are- to counteract the rising response they tend to have..
I'm going to do measurents on the following.
1 x Seas driver FR
2 x Seas drivers FR
2 x Seas drivers 1 FR the other with low pass filter
Horn with high pass filter (around 9 to 10kHz) + 2 x Seas Drivers FR
Horn with high pass filter (around 9 to 10kHz) + 1 × Seas Driver low pass around 9kHz the other with low pass around 160Hz
Horn with high pass + 1 x Seas with low pass + 1 x 12" with low pass.
There are few more variations I can think of but I'll let the measurements and ears dictate what changes I will make to crossover and driver combo etc.
I just threw it all together quickly. I don't like to let textbooks get in the way of having fun.
Once I'm happy I'll rebuild.
I tryed to change the IRFP240 when I built my ACA with the 044 to have better bottom end and maybe lower distorsion but the result was good on it but higher frequencies where attenuated too much so I replaced again with IRFP240.
Mark: Here are some notes I tucked away about different IRFP devices - I think these came from the huge Aleph-X thread long ago...
IRFP044 vs IRFP240 vs IRFP244 vs IRFP250 : A number of amps have been built using each of these transistors. Nelson has characterized the differences among the three latter transistors as follows: The 250's have greater current capacity, but twice the capacitance of the 240's and 244's. They will give a better bottom end, and will sound a bit different, for better or worse, depending on your situation and taste. There is very little practical difference between the 240's and 244's. Some have reported that the IRFP044 sounds a little "darker" (more narrow frequency bandwidth and greater high-frequency roll off) than the 240, though this is not really surprising as the 044 has greater capacitance than the 240 series. Essentially, greater capacitance provides slightly better bass, but at the cost of slightly reduced treble. The practical difference, though, is their current capacity. The maximum current and operating temperature ratings have lead many to use the IRFP240/244 for rail voltages of 20v or higher, while using the IRFP044 for 15-20v rails. The lower voltage versions of the amp tend to feature higher current, and the 044's can handle significantly more heat.
Device (Max Voltage, Max Current, Max Temp)
IRFP044 (60v, 57A, 175c)
IRFP240 (200v, 20A, 150c)
IRFP244 (250v, 15A, 150c)
Hi everybody, I'm from Italy and I'm trying to build my own ACA but I've came across some issues.
I've got everything I need from digikey, and I've built myself the PCB.
First of all, when I measure the voltage from the input connector (3,5 Jack), I see at least 1V, that in a couple of seconds turn down to zero. Is that correct? Could this Voltage possibly damage any external hardware connected ?
Yes, I've Made 2 pcb and change all the components to be really shure, but the problems remains! Speaker connected everything Seems to be right!
Don't look at those little dissipators, they are just hooked for testing.
Already check for any short circuit, but everything Seems to be right in place.
if amp is working , and that input offset goes in few seconds to zero , even loaded with MegaOhm input resistance of DMM , everything is alright
that's due to construction - having 10K in series with input and input cap really not significantly grounded
so , enjoy .....
so , enjoy .....
After finding both supplies and powering up both channels for first time, one amp starts buzzing through the loudspeaker and progressively becomes louder.
Mosfets are drawing 1A and getting 10V between middle pin of Q1 and Ground.
All I can think of is bad Output cap?
Bad Jfet?
It's 2am got to go to sleep
Bad Jfet?
Bad Jfet?
Have you tried swapping the power supplies side to side? You may have a bad smps . A wise man once told me to try the easy things first. I'm still trying to remember that (but usually forget).
Yes swapped power supplies.Have you tried swapping the power supplies side to side? You may have a bad smps . A wise man once told me to try the easy things first. I'm still trying to remember that (but usually forget).
you really need help troubleshooting amp with 3 parts in it ?
Hahaha.
Probably not. It was late at night.
First time I've ever had a fault to find in one of my own builds.
Still in disbelief. Hahaha.
I'll have a look at it properly when I get home.
Is there an updated parts list/part numbers for v1.3? Mainly looking for the power connectors that thread into the chassis, as the female plug on one does not go in as much as the other.
Have you tried using brute force?
Hehehe
Hehehe
As a matter of fact yes. And with a sledgehammer.
- Amp Camp Amp - ACA
