Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 22nd July 2013, 10:09 PM   #1161
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Amp Camp Amp - ACA
We've added just the parts kit- including the PSU's, back on the order page so people who don't want to pay for shipping the chassis to their country have an option. I believe that if you add up all the bits and pieces it is price competitive with small quantity orders of parts at Digi-Key or Mouser. And if not, certainly when you count the time to make up an order!
Originally Posted by speedless View Post
Hi
Just to inform any one living in EU and having a hard time getting there bits and pieces.
Try DIGIKEY´s site.
Normally I would not advertice for anyone,but compare the product index,prices and shipment terms/price.
Just ordered the parts for the ACA and some for the PLH.
Waiting for that magic moment: "Your order has been send"
Jan
PS:
Meant the parellel version of the PLH.
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 22nd July 2013, 11:48 PM   #1162
propitious is offline propitious  United States
Amp Camp Amp - ACA
ACA dual mono power supply
To see what it sounds like, I am going to build a dual mono ps for my ACA's just because I have a bunch of capacitors and a pair of Antek 50VA 15VAC transformers lying around. With a 1ohm load I am not sure what exactly the rail voltage will be. Would it matter if the voltage is closer to 20VDC than 19VDC? If so, should the voltage on Q1 be adjusted a little higher than 10VDC?
Old 23rd July 2013, 12:17 AM   #1163
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
just go for it
no need for readjusting for so small difference
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 23rd July 2013, 01:12 AM   #1164
Loudthud is offline Loudthud  United States
Loudthud's Avatar
The distortion at 1W changes quite a bit as you adjust the pot. I documented this earlier in this thread as far as distortion plots will show. A serious listening test is the only way to determine what you will like. Changes as small as 1V are easily measurable.
Old 23rd July 2013, 12:58 PM   #1165
speedless is offline speedless  Denmark
speedless's Avatar
Hi
I really would haved liked to order a kit but unfortunally the price for a kit from US,send to Denmark is ridiculus,not blaming aca,its the shipment and on top 25% danish tax.The pcbs alone at 20$ will end up near to 60$
Jan
Old 23rd July 2013, 01:01 PM   #1166
boatbuilder is offline boatbuilder  Netherlands
it is such a simple design.
just point to point it.
Old 23rd July 2013, 02:30 PM   #1167
Zen Mod's Avatar
Amp Camp Amp - ACA
agree with that
my comment was about difference between 19 and 20V PSU , while setting procedure remains the same
Old 24th July 2013, 04:01 PM   #1168
Default heatsinks
would this heatsink be enough for one channel?
size is 12 X 8 X 8 CM backplate is 7 or 8 MM
Old 24th July 2013, 04:08 PM   #1169
Eric is offline Eric  United States
Eric's Avatar
Amp Camp Amp - ACA
I would think that sink is perfect for one channel. My guess is that it might run a bit cool.
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based DCB1 + BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 24th July 2013, 04:11 PM   #1170
thanks Eric.
maybe you are right and it will run a bit cold, would be my second class a that does not get hot. although, this is not going to be mine, my son is going to build it,...... with my help.
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
