Amp Camp Amp - ACA
Amp Camp Amp - ACA
Old 3rd June 2013, 10:46 PM   #1041
Eric is offline Eric  United States
Eric's Avatar
Amp Camp Amp - ACA
Cool! I think that one wins the award for the most compact chassis! Nicely done.
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based DCB1 + BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 3rd June 2013, 11:02 PM   #1042
billyk is offline billyk  United States
billyk's Avatar
Wow! That is one sweet looking set!
Old 4th June 2013, 12:07 AM   #1043
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Amp Camp Amp - ACA
I'd be very proud of those monoblocks if they were mine! In fact I believe I have a couple of very similar heatsinks.. and now I know what to do with them!
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 4th June 2013, 12:09 AM   #1044
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Oooo La La.
...Shape the sound , Man!
Old 4th June 2013, 07:32 AM   #1045
likeDIY is offline likeDIY
Does any know if I can use the LU1014D (used in Zen V9) for this circuit? Any modification is required if I want to use this?
Old 4th June 2013, 08:08 AM   #1046
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Amp Camp Amp - ACA
whenever you think of LU , take cascode as native part of it
feel free to try it
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 4th June 2013, 11:55 PM   #1047
bcmbob is offline bcmbob  United States
These are my readings with the PC coolers on my ACAs:
Ambient = 27 C
Tj = 44 C
44 - 27 = 17 C raise
17 / 20 = .85 c/w
I think I can do better because I used PC CPU heat transfer tape to mount the transistors. I now have some mica spacers I can install. I'll post again when I get it done.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 5th June 2013, 02:17 AM   #1048
Eric's Avatar
Amp Camp Amp - ACA
Hi Bob,
A 17c rise over ambient is pretty decent. This is very similar to the thermal behavior of the ACA on the sinks that sell with the kit or the 2U sinks that were available in the DIYAudio store. The one that my daughter and I built sees a 18-19c rise and is quite comfortable to the touch (not too hot at all). For the thermal interface, I used Begquist K-10 SilPads. Years ago, I got my hands on a 4" by 4" sample sheet that I cut to size for my needs.
Old 5th June 2013, 10:09 AM   #1049
That's funny - years ago, I bought 2" X 18" roll of double sided heat transfer tape for computer building, and these were the last four pieces I could salvage.
BTW, I placed the probe on the thick web of the heat sink and not on the thin fins. I'll do both next time.
Bob M.
Old 20th June 2013, 03:24 PM   #1050
ottopilot is offline ottopilot  United States
I bought the kit from the store and have decided to build a linear supply with CLC filter for it as a learning effort.
While researching the design and picking an inductor, I've run some simulations and determined that the size of the inductor really doesn't affect the waveform shape that much, so whether I pick a common value like 2.2mH or go up to something like 8mH, it serves the purpose. But the value does clearly affect the resonance frequency, and therefore the effectiveness of the filter at 120Hz.
I read somewhere the resonance frequency should be below 10Hz but this statement was made in the context of a supply for a tube amp, which is obviously a different animal. Using the standard formula for LC resonance I came up with 34hz for 2.2mH and 17Hz for 8.5mH.
Question I have is this: do I really need to keep the resonance below 10Hz or some other value? Or is not a factor for the ACA (or any transistor amp design)?
Amp Camp Amp - ACAHide this!Advertise here!
Amp Camp Amp #1 Nelson Pass diyAudio.com Articles 54 8th May 2018 03:13 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
Best D camp config for Tweeter amp Zero One Class D 0 24th February 2010 04:57 AM
better the Pass camp? rick57 Tubes / Valves 6 26th March 2005 06:04 AM
