I agree, it is almost always a small DC voltage on the signal line.
The DC changes with level and causes the pops.
Also known as zipper noise when you rapidly change levels.
It sometimes happens with some steps, not with others, that is because the effect is greatest with greatest steps.
For instance, going from -15dB to -16dB may involve engaging the -16dB relay and disengaging the -8, -4, -2 and -1 dB step relay.
Try to insert a capacitor between the signal and the input to the level control. If the pop is gone, it was the DC. Note that even a few mV can cause this!
jan didden
jan didden
Or firmware change. First turn the relays "OFF" (max attenuation), and then enable the needed relays. .
... which will give you two pops. I would attack the cause, clean up the DC on the signal line.
If your relays switch to "ON" faster than to "OFF" (given the "ON" increases output), you could get much more pronounced "POP" than two controlled "POP"s at lower volume...
Needs to be checked first to be viable solution, i've seen such solution as the "POP"s fighting method.
This one could be good for "01111111"->"10000000" transition.
Alternatively you can use a binary code without rough "01111111"->"10000000" transitions such as... ehm i forgot his name. The one which for every numeric increment changes just one bit. Then rearrange the relays/resistors to support such binary code.
Gray code, that's his name.
Emm... Is it feasible to implement it with resistive ladders? I am puzzled.
I guess the answer is "No"
Although someone did R2R DAC with it - http://www.google.com/patents?id=DOQ4AAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q&f=false
If your relays switch to "ON" faster than to "OFF" [snip]
Yes, as long as the DC is there. You can change the way you switch a myriad ways until you are blue in the face: as long as there's DC you'll have pops.
jan
instead of opening an new thread I think this will fit in here.
I´ve also got a loud popping sound using an 6bit r2r volume control (1.5dB steps) with my X-BOSOZ.
There are only two positions where the pop occurs, going from -46.5 to -48dB (very loud) and from -48dB to -46.5 dB (loud). So from 011111 to 100000 and back.
The problem seems to be the 48dB jump (there´s no DC and no pop when there's no input signal)
The very loud pop could be avoided by changing the order of the relais switching (first switching the -48dB relais) but I´ve got no idea how I can avoid the loud pop as there will always be a 48dB jump in loudness regardless of when I switch the relais.
The volume control had 1dB steps before I changed it to 1.5dB and I´m not sure the pops where there before (occurring from -31 to -32dB) as I was´t in the range very often.
I changed it because -63,5dB was still too loud with some sources.
Any ideas if these pops are normal and how to avoid them without using a mute relais or making the steps smaller using 7 or 8 relais?
William
William
two step volume change.
first switch attenuating relays, then switch un-attenuating.
somth like that. helps.
the idea behind is to always have less volume than required during switching transition.
So if you want to go from -47 to -48, you want to go thru -47, -?99?, -48. Currently you get -47, -?5?, -48.
**numericals are imprecise **
- "pop" noise in relay volume control
