"pop" noise in relay volume control
Old 27th June 2012, 07:41 PM   #11
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
yeah
every time I dismantled DAC chip with ladders , I found several relays in there
in fact , I'm not buying relays anymore - have enough DAC chips as donors
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th February 2015, 06:01 PM   #12
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
instead of opening an new thread I think this will fit in here.
Ive also got a loud popping sound using an 6bit r2r volume control (1.5dB steps) with my X-BOSOZ.
There are only two positions where the pop occurs, going from -46.5 to -48dB (very loud) and from -48dB to -46.5 dB (loud). So from 011111 to 100000 and back.
The problem seems to be the 48dB jump (theres no DC and no pop when there's no input signal)
The very loud pop could be avoided by changing the order of the relais switching (first switching the -48dB relais) but Ive got no idea how I can avoid the loud pop as there will always be a 48dB jump in loudness regardless of when I switch the relais.
The volume control had 1dB steps before I changed it to 1.5dB and Im not sure the pops where there before (occurring from -31 to -32dB) as I wast in the range very often.
I changed it because -63,5dB was still too loud with some sources.
Any ideas if these pops are normal and how to avoid them without using a mute relais or making the steps smaller using 7 or 8 relais?
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 24th February 2015, 07:02 PM   #13
Zen Mod's Avatar
useful trick is to find specific relay position and solder 470-1000uF in parallel to coil , to slow it
sometimes simpler than changing software
Old 24th February 2015, 07:18 PM   #14
wuffwaff's Avatar
I wrote the software myself so that would not be the problem. It has to react differently depending on going up or down so slowing it down would only help one way.
William
Old 24th February 2015, 10:51 PM   #15
wayne is offline wayne  United States
Auburn
wayne's Avatar
Relay resistor configuration can do this even with no DC. What is the schematic like and type or relays?
wizards assistant
Old 25th February 2015, 05:09 AM   #16
wuffwaff's Avatar
relais are miniature 5V relais from F.T. type B4A4.5Z. Schematic is as in the pic.
William
Old 25th February 2015, 05:37 PM   #17
Auburn
wayne's Avatar
Do look for any DC coming in. Relays like this work well because they make contact quicker than break.
wizards assistant
Old 26th February 2015, 02:10 AM   #18
wuffwaff's Avatar
Hi Wayne,
Like i mentioned before, no DC and no noise when switching without a signal. I think I will try to change the 48dB step into 2x 24dB steps.
William
Old 26th February 2015, 06:23 AM   #19
s3tup is offline s3tup
s3tup's Avatar
two step volume change.
first switch attenuating relays, then switch un-attenuating.
somth like that. helps.
the idea behind is to always have less volume than required during switching transition.
So if you want to go from -47 to -48, you want to go thru -47, -?99?, -48. Currently you get -47, -?5?, -48.
**numericals are imprecise **
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 26th February 2015, 01:17 PM   #20
wuffwaff's Avatar
First switching the attenuating relais is what happens going from -48!to -46.5dB. Here the pop is not as loud as the other way round but still too much.
William
"pop" noise in relay volume controlHide this!Advertise here!
Fostex Volume Control "PC1EX" - Schematic wanted tiefbassuebertr Analog Line Level 7 12th July 2012 04:11 PM
ta2020 anti "pop noise" relay - really needed? yakideo Class D 5 18th July 2011 03:28 AM
Reduce "pop" noise when power on/off veckans Class D 11 28th January 2009 09:53 AM
relay volume control - POP! wayne325 Pass Labs 22 26th August 2006 01:58 AM
"non direct" volume control Glass_painter Tubes / Valves 2 25th September 2003 07:09 PM
