Fresh F5 Build - diyAudio
Old 24th June 2012, 08:13 PM   #1
willamp is offline willamp  United States
willamp's Avatar
Default Fresh F5 Build
Hi All,
Almost finished with my first F5. Spent over 4 hours listening to it last night. It sounds great! Much more detail than the tube amp I've been using for the last four years. It's like a vail has been removed from the music. Soundstage is much more detailed and precise. Bass is much more controlled. Which makes sense considering the drastic increase in damping factor. My tube amp has on output impedence of 4.5 Ohm so really bad damping factor.
My build seems to be performing as expected. Gain is 15.4db. I wanted to check THD but alas it is lower than what my old HP distortion analyzer can measure. Measuring the internal oscillator I am starting out at 0.0068%. Higher than the 0.002% Mr Pass mentions for the F5. I took some measurements at different wattage ratings anyway but there are some inconsistencies in the numbers and nothing to really say the F5 is anything other than <0.002%. The only thing I saw is one channel seems to have slightly higher distortion than the other. Odd think is the one with higher distortion is biased slightly lower than the other.
Currently I'm running only around 1 amp of current but will increase to 1.3 after I replace the R11/12 and re-bias. I did a stupid thing of not zero-ing the trim pots before powering on and beginning biasing. They were set to around 2k Ohm so I was probably running around 2 amps for a short while. The resistors turned a bit brown so I ordered some replacements. Everything else seems to have survived the abuse OK.
My heat sinks only reach ~42 degrees C when things stabilize so things seem OK there. I do wonder how things will fare with the case top installed. This case has no venting which I didn't think about earlier. Does anyone think this will be a problem? I just now turned the unit on with the case top in place and a temperature probe inside. I'll report back where it ends up. I would think it would be the same as my heat sink measurement but that was with the top off, so maybe it will be higher too.
I'm currently missing the 0.0033uf cap across the mains input indicated in the PSU schematic. I have one on order now though. Can someone tell me the function of this cap? Is it a high freq filter by any chance?
Anyway I'd like to thank Mr Pass and all of you diy'ers who share your knowledge and experience. As it was I spent many months researching and gathering parts and can't imagine how long that would have taken without all of your help (unwitting, and otherwise).
Sorry for the fuzzy pictures, my wife's out of town with the good camera.
Old 24th June 2012, 09:09 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
you need vents on both bottom and top
source resistors are still fine , after conducting 2A for some time
function of 3n3 cap across mains is filtering of mains crap ; you can live without it
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th June 2012, 09:26 PM   #3
willamp's Avatar
Thanks for your input. As much as I don't want to take everything apart again I believe you're right. Looking at my layout can you make a suggestion of the best way to add them? I can only think of drilling many holes on the drill press. Or, maybe cutting out some openings with a coping saw or a nibbler and attaching a metal screen over them.
Thanks in advance for any suggestions
Old 25th June 2012, 01:36 AM   #4
For the top, I just "spacered" mine so it floats about 1/2 high...1/2 space all the way around ventilates well. At least for the top.
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 25th June 2012, 01:45 AM   #5
Zen Mod's Avatar
yup - spacers are effective and certainly most easier solution
but - only if you can make same for both top and bottom plates
no use of making escape way for air , if not making inlet way
Old 25th June 2012, 02:05 AM   #6
Oh well, at least holes drilled in the bottom plate dont show as badly as in the top plate!
Russellc
Old 25th June 2012, 01:39 PM   #7
willamp's Avatar
I think I'll contact my case supplier and ask them to make a ventilated top. Then I'll modify the bottom cover myself. Not sure why they didn't have the case ventilated in the first place.
Thanks for your input guys.
Old 25th June 2012, 01:45 PM   #8
i gues this is a par-metal chassis?
Old 25th June 2012, 02:23 PM   #9
willamp's Avatar
Yes, that's right.
It's ironic, I used one of their chassis for my passive pre-amp which has no active components.....and it has major ventilation on top and bottom...just to let dust in on my expensive auto-former attenuators
Old 25th June 2012, 03:16 PM   #10
hehe but they do machine part on demand don't them?
How to build the F5 6L6 Pass Labs 1133 23rd January 2014 06:32 PM
oneplustwo F5 build thread oneplustwo Pass Labs 251 30th May 2012 10:36 PM
FS: Parts for F5 build Jimmy D. Swap Meet 2 5th July 2011 05:33 PM
Next suggested build after F5 anilva Pass Labs 36 3rd December 2010 05:11 AM
F5 Build Instructions 1108 Pass Labs 4 12th May 2009 11:58 PM
Copyright 1999-2017 diyAudio
