Balanced Zen Amp info needed (not line stage)
Old 14th October 2003, 04:11 PM   #1
Alfetta87 is offline Alfetta87  France
Alfetta87's Avatar
Default Balanced Zen Amp info needed (not line stage)
There is a sympatic guy in Croatio who offers nive PCB for some Aleph projects (http://web.vip.hr/pcb-design.vip/index.html).
He proposes a PCB of a Zen Balanced (power) amp, for which I couldn't fine any info or thread (yes I searched, but it would take a week before going tru all the threads...).
Actually I'm interested in this one because... the PCB size fits in the case that I want to use (an old french-made Cairn K3 Mosfet amp, which sounds like sh..), it has huge heatsinks and is perfect for a DIY'er who is too lazy to build its own case (and it looks nice, beside that ).
Pass' website doesn't give any info for that beast.
Has anybody built it?
Thanks,
- dan
Old 15th October 2003, 07:53 PM   #2
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
sorry; no info, but you should ask kristijan directly (email). he'll help you out
Mads K
Old 27th October 2003, 11:41 PM   #3
tomchaoda is offline tomchaoda  United States
Default BZLS Cap
I am making my Balanced Zen Line Stage PCB now. In the article, Nelson suggest using 100+ Volt rating capacitors. I have both 1500uf/160V cap and 3300uf/63V on hand. If I use the latter one, will it works OK? or should stick on the higher volt rating one? (I like to pick the latter for better smooth out the ripple effect!)
Any suggestion?
Thomas
Old 28th October 2003, 08:11 AM   #4
Alfetta87's Avatar
Lightbulb 63 volts caps vs. 160volts
Unlike film (plastic) capacitors, anelectrolytic caps increase its lossfactor with its voltage capacity. Means qualitywise you better use the 63V caps, but note that the voltage in the Balanced Line Stage PS is about 80V after the rectifier!
You may use them after regulation, where the voltage is about "only" 60V per rail.
- dan
Old 28th October 2003, 05:10 PM   #5
Mad_K's Avatar
Default Re: 63 volts caps vs. 160volts
- dan
isn't it the other way around? -loss decreases with voltage rating?
Mads K
Old 29th October 2003, 01:11 AM   #6
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Balanced Zen amps are well described in the ZV series.
See them at www.passdiy.com
Old 29th October 2003, 06:52 AM   #7
Alfetta87's Avatar
Default Lossfactor in caps
No, Electrolytics increase their Lossfactor with the voltage increase. Film caps [I]decrease[/] their lossfactor with the voltage increase.
- dan
Old 29th October 2003, 07:04 AM   #8
Alfetta87's Avatar
Default Lossfactor in caps -2-
We have to relativilize this though: a cap from a same manufacturer in a given capacitance and a voltage of f.e. 63V has a better lossfactor than the same capacitance (and construction) than a 100V or 160V. In a case of two different types (brand, construction, size...) you have to check from the manufacturer's datasheet which one is better.
Note: a cap with lower loss factor (and ESR) will heat up less at its limit of voltage than a worse lossfactor, means can be driven harder to its limit.
Connect and touch it, if it heats up too much, change them. They will not blow away immediately. But wear some protection glasses though, you never know...
- dan
Old 29th October 2003, 04:11 PM   #9
stappvargen is offline stappvargen  Sweden
What is this "lossfactor" you speak of called in the datasheet of a capacitator? Just curious...
For instance the Panasonic FC series have the following data:
Rated voltage 6.3 10 16 25 35 50 63 100
Tan d 0.22 0.19 0.16 0.14 0.12 0.10 0.08 0.07
The ESR for the value 470 uF for the same brand of caps :
Rated voltage, ESR:
6.3, 0.117
10, 0.117
16, 0.09
25, 0.068
35, 0.052
and so on.
Old 29th October 2003, 06:29 PM   #10
usekgb is offline usekgb  United States
usekgb's Avatar
Default Re: Balanced Zen Amp info needed (not line stage)
One simple and effective way to make a balanced amp is to use two amplifiers. The first amp is used just like normal. The second amp recieves the inverted signal of the balanced input. The first amp is connected to the + input of the speaker, and the second amp is connected to the - input of the speaker. This gives you a nice balanced/bridged amplifier with slightly lower distortion than a single ended amplifier. The only thing you might have to do is come up with some way of balancing the inputs if you are not using a balanced pre-amp.
Zach
Balanced Zen Amp info needed (not line stage)Hide this!Advertise here!
balanced line stage Alessandro Pass Labs 5 30th March 2006 02:14 PM
balanced line stage schematic needed jogas Tubes / Valves 3 11th September 2005 09:57 PM
Balanced Zen v5 + balanced Zen line stage Adrie Pass Labs 0 30th May 2004 06:27 PM
Balanced Zen Line Stage Mad_K Pass Labs 55 30th December 2003 09:03 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 07:18 AM
Copyright ©1999-2017 diyAudio
