F3 and F1 boards
Joined 2000
Here you go! This is the F3 power supply. The secondaries will give you 36v and 50v after the bridge. That's 1 channel.
If you want to power 2 channels with one transformer, use a 36v-0/36v-0 at around 8-9 amps, 575VA or higher. F3 draws around 2.2 amps constantly.
Be sure to use 4 .47, 3w resistors in the CRC of the filter bank.
Hope this helps.
Zen Mod and Flg,
I read the differents manuals of F1,F2,F3,F4 and F5 amp's.
I anderstood, the Nelson Pass PSU is general PSU for all the circuits whith 3 optional DC tension of 46V, +- 23 V or +23 V with the same components.
And the board is avaible in the store of this forum.
I don't ask the evidence, sorry.;)
Best regards
EBA
