channel distortion
channel distortion
Old 12th February 2002, 06:50 PM   #11
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
channel distortion
Round up the usual suspects. Start with the
Zeners.
Old 12th February 2002, 07:15 PM   #12
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
Grey,
normally kapton insulators have a significantly lower thermal resistance (0,07 K/W) than mica + silicon grease. Why donīt you like them? (Please donīt give me a good reason cause there are about 24 lying around here waiting to get used in my Aleph)
william
Old 13th February 2002, 02:30 AM   #13
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
channel distortion
Originally posted by wuffwaff
Grey,
from memory, that's for hockey puck style mounting @ very high pressure.
Old 13th February 2002, 02:38 AM   #14
GRollins is offline GRollins  United States
Hmmm...
You ask for a reason, but <i>not</i> a good one. Why didn't you set me an easy task, like cleaning the Stygian stables?
Uh, well, okay, how 'bout this? One of my degrees is in geology and I find mica (biotite, muscovite, et al...) inherently more interesting than a man-made material.
Not good enough, huh?
Okay, well, from a tree-hugger's perspective, mica is a natural material that won't hurt bunny rabbits, box turtles, or kangaroos. The research on pandas isn't in yet, so they'll just have to take their chances.
Ah, fooey, go for the jugular...
I'm a naturally suspicious, cynical critter who feels that every new technology is guilty until proven innocent. I've heard too many people complaining about problems with 'em. In my view, if your cooling is so marginal that the 1 bazillionth of a degree difference in cooling between mica and Kapton is all that stands betwixt you and a puddle of slag that used to be an amplifier, you need bigger heatsinks.
Besides, you can see through mica...and we all know that transparency counts in audio.
Grey
Old 13th February 2002, 10:09 AM   #15
macka is offline macka
macka's Avatar
Default static
Scott,
Always check the least obvious..
You mentioned you still get static after changing the insulation.
washers.. but disappears after a little while.
The problem could be heat or a fault mechanical connection
1. Have you metered the insulation for each hexfet (with hot and cold heats), there could be a problems with the mounting bolts on the hexfets.
2. Are the heat sinks and the chassis earthed to the mains plug ground(not the 0 volt ground which should only be in connection with the chassis at one point).
Test for zero ohms for the faulty channel. or tighten any bolts or other offending hardware.
I have found that if the heat sink is floating you get static in the output .
3. The power supply.
If the Led flickers either the positive rail or output are shifting for some reason obviously.
This could be due to loose screws in your power filter capacitors for that channel or a dry joint somewhere(I had this problem).
4. The fact that you only have this problem in one channel suggests that all things being equal it is not component failure if everthing was previous replaced.
(But not with standing this one of the capacitors (or zeners) could be routed so replace if all else fails.. capacitors are strange and they can be intermitently faultly and change with heat).
I hope these suggestions help at least solve the problem by process of elimination.
regards
macka
Old 13th February 2002, 06:23 PM   #16
wuffwaff's Avatar
Grey,
thank you very much for this very nice reason: I will use the ones Iīve got and buy mica again for the next amp!
This will save all the nice little bunnys that live here (no kangeroos nor koalas Iīm afraid)
william
channel distortionHide this!Advertise here!
strange distortion on one channel of cd player Luke Digital Source 13 18th December 2008 05:43 PM
left channel distortion mic_ael Chip Amps 6 17th February 2006 12:13 AM
How do n- and p-channel fets cancel distortion? jwb Solid State 2 1st December 2004 08:05 PM
distortion in one channel randytsuch Chip Amps 1 3rd October 2003 07:25 PM
distortion in one channel of tube amp fragman56 Tubes / Valves 6 27th August 2002 12:17 AM
