Wiring Attenuator for dual channel Balanced
Old 11th December 2012, 12:36 PM   #11
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
Originally Posted by AndrewT View Post
With a balanced interconnection, the impedance on both the hot and cold are identical. If they are not identical then the interconnection is not balanced.
The attenuator must insert identical resistances into both the hot and the cold poles of the signal connection.
Yes that is true, and that is the nice thing about this balanced attenuator. It only switches one restistor between hot and cold (after the two series restistors) so it is always balanced perfectly.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 11th December 2012, 12:39 PM   #12
Originally Posted by wuffwaff View Post
...............so it is always balanced perfectly..................
Is it?
What is the channel matching tolerance?
regards Andrew T.
Old 11th December 2012, 12:51 PM   #13
wuffwaff's Avatar
the chanel as such is balanced perfectly (you can match the two series resistors if you think 1% isnīt enough or use 0,1% as I did).
Between left and right channels you can get 1% when using 1% resistors. In dB that would not be very much.....
cheers,
William
Old 11th December 2012, 12:55 PM   #14
between hot and cold.
0.1% is usually the biggest acceptable tolerance. That is half the tolerance of using +-1% resistors. Some would say you should be aiming for better than 0.01% for hot to cold channel matching.
I don't care if it's -30.02dB or -30.09dB
regards Andrew T.
Old 11th December 2012, 01:17 PM   #15
wuffwaff's Avatar
Andrew,
Iīm not sure we are talking about the same thing.
Iīll try to say it more precisely:
The attenuation by changing only one resistor (between hot and cold) wonīt change the balance (between hot and cold) of this channel. It will stay as it is.
If the balance between hot and cold needs to be better than 0,01% I donīt know. This would mean using only precision resistors to set the gain and attenuation. Most preapms using 4-way pots and 1% resistors (at best) will never get near this value.
william
Old 11th December 2012, 01:29 PM   #16
yes you have identified the problem.
Balanced requires precision matching of impedances.
Throw away precision and you throw away all the advantage that balanced brings.
regards Andrew T.
Old 7th May 2013, 05:22 AM   #17
hschaser is offline hschaser  Singapore
hschaser's Avatar
Hi all... Thank you for all ur precious advices . The attenuator now works fabulously. I used a 50k pot instead of 10k as recommended. I would also like to find out with this configuration can I use a 100k pot ? Also for both the 5K resistors is there any power rating or requirement? (I.e 1/4 watts or something with bigger values? Thank you once again you had been a fabulous people.!!!
Wiring Attenuator for dual channel BalancedHide this!Advertise here!
In-line attenuator for headphones (wiring)? Norfox Everything Else 6 19th March 2010 03:38 PM
H Type Balanced Attenuator. GeeVee Pass Labs 24 17th July 2008 07:39 PM
Looking for Balanced attenuator ideas cartman Analog Line Level 11 30th May 2008 03:11 PM
DIY Fidelity attenuator wiring - help please tfowler Class D 10 3rd December 2006 06:33 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 05:37 AM
