Old 10th October 2003, 01:50 PM   #1
Default ALEPH P1.7 CAP values/mods
Hi all
I am in the process of sourcing components to build an Aleph P1.7 Clone
One of the significant costs is the capacitors used in the output legs of the circuit, namely C10-13 and C14-16. each is noted as 10uF.
I am trying to use WIMA MKP4’s for each of these
The 3 caps in the output are paralleled to equate to 30uF
Unfortunately these are rather costly at approx $10 AUS each..
My question is this, what would happen if I used 1 off 10uF cap instead of 3 off to each +ve & -ve leg?
Would the LF roll off rise by a factor of 3? (quoted in spec’s as being down 3dB at 1Hz) to 3Hz??
Am i missing something?
Pardon my ignorance
Regards and thanks in advance
george a
Old 10th October 2003, 06:46 PM   #2
The one and only
Nelson Pass's Avatar
The original circuit used 10 uF at the outputs, and I
think it worked fine. The 3 Hz figure presumes loading
something along the line of 5 Kohm, so if you load it with
a higher value, you can go lower in frequency.
Old 10th October 2003, 07:35 PM   #3
Jaac is offline Jaac  Netherlands
Jaac's Avatar
hi there iám also building a aleph p 1.7 i've designed a board that let me play with the valeu of that output cap currently i'am using two wima mkp4 10uF parallel maybe i will make this 30 uF in the futere if i can here the difference
gr jaac uit TUK
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
Old 11th October 2003, 12:43 AM   #4
Nelson
Thanks for your very prompt reply!
Your response leaves little issue for discussion!- I'll just plough on forward!
BTW have you had any chance to mull over the following thread?
http://www.diyaudio.com/forums/showt...994#post235994
This posting by Mark Finnis relates to an alternative way of achieving a simplified volume control for the P1.7's that he and I will be building concurrently.
many thanks again, your kind efforts on this forum are effectively allowing me to achieve the equivalent in HiFi terms of the Sports car I can't afford to buy to battle my mid-life crisis.
"My regards to you and anyone else you might happen to bump into" Quote- Elwood P. Dowd.
george a
Old 26th January 2005, 12:48 AM   #5
Stabist is offline Stabist  Slovenia
Stabist's Avatar
Mr. Nelson - so I guess - if matching AP with A5 with 10Kohm SE input and 25Kohm balanced input - 10uF will be more than enough - and so no need to parallel three of them?? Thanks!
Old 26th January 2005, 12:59 AM   #6
Gaucho is offline Gaucho  Canada
Gaucho's Avatar
1/(2PiRC)=cut off freq (-3dB)
1/(2Pi*10k*10E-6)=1.59Hz
10uF should be lots, unless you perhaps require deeper bass!
Old 26th January 2005, 01:09 AM   #7
Stabist's Avatar
Hehe - you now - it's never too deep
Old 26th January 2005, 04:56 AM   #8
Send a message via Yahoo to karnovim_salim
Default 1.7 output capacitors
Hi all......
For the Aleph 1.7 output capacitor that is consisting of 3 x 10uF, not only for the purpose of lower frequency, but I guess more the 'sense of body' since the output volume control acts as a load to the pre-amp circuit.... The lowest the volume, the lower resistence, the more output is loaded.
You could test it with 30uF single caps and then parallel 3 x 10uF and feel this effect.... I have my own experiments and the experience told me so...
Just bear in mind, never use 'too big' output caps, since the sound just like when you use a graphic equalizer with V frequencies setting. Very un-natural and metallic on its high frequency...
I hope this will help you, and See you, guys....
Old 26th January 2005, 07:41 AM   #9
JEKYLL is offline JEKYLL  France
George, if you want to save money, maybe would it be possible to use a 1 µF capacitor for the inputs like in the first ALEPH P.
But I'm not sure.
Old 26th January 2005, 12:53 PM   #10
Default what about the volume control
The volume control shown for the P1.7 is also connected to ground. Not knowing the microcontroller details, I can't know the resistance for sure. However, it seems reasonable that the volume control could, for some volume levels, be as low as a 250 ohm load.
In that case the cutoff frequency (-3dB) is
1/(2Pi*250*30E-6) = 21 Hz
That is pretty high.
If you use a 5k or 10k pot instead, then you have no problem.
Jeremy
Aleph x resistors values elviukai Pass Labs 15 29th May 2006 06:56 PM
what are the aleph 1.2 resistor wattage values? Shaun Perez Pass Labs 3 23rd October 2002 08:16 AM
Power resistor values in Aleph 5? Tony D. Pass Labs 19 10th October 2002 08:58 PM
Capacitor values on Aleph 5 main board. Tony D. Pass Labs 1 2nd October 2002 09:42 PM
Resistor values for Aleph-X nar Pass Labs 1 23rd July 2002 07:29 PM
Page generated in 0.10075 seconds (85.54% PHP - 14.46% MySQL) with 10 queries
