Pics of my aleph 2 and problems! - diyAudio
Old 26th May 2012, 04:19 PM   #1
Coque is offline Coque  Spain
Default Pics of my aleph 2 and problems!
Hello all and thanks for this great forum;
I'm a long time reader but first time poster
Here you can see some pics of my aleph 2. The amp is finished but when I turn it on, the woofer of the speaker "pops out" .Without any imput signal you can see the speaker at its maximum excursion permanently, it's not centered. If you conect the preamp to the amp, you can hear music, but it distorts because the woofer it's allready at its maximum excursion.
I have replaced all the irf9610 and bc55. I have replaced everything except the irfp240.
Even i have replaced the pcb's.
Can that be caused by a faulty irfp240?
Te irf9610 measure like this:
Q2:
GS= 4,1
GD=56,8
DS=60
Q1:
GS= 4,1
GD=55,8
DS=55,6
Q3:
GS= 4,1
GD=45,7
DS=45,2
Please i need help, i spend tons and tons of hours on this great amp
Also here you have more measurements and pics:
Old 26th May 2012, 04:28 PM   #2
KatieandDad's Avatar
You can test the IRFPs by measuring the volt drop across each source resistor.
Don't use your speakers until you have sorted out the DC offset.
Old 26th May 2012, 04:30 PM   #3
my guess is that you have a big DC offsett.
and you may also have a cooling problem. those sinks looks way to smal.
Old 26th May 2012, 04:34 PM   #4
What are the voltages across R11 and R14 ?
The heatsink issue will rear its ugly head as we get the thing working.
As long as its not blowing fuses and roasting components it should be OK for the short tests that we are going to perform.
Old 26th May 2012, 04:44 PM   #5
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Q2:
GS= 4,1
GD=56,8
DS=60
Q1:
GS= 4,1
GD=55,8
DS=55,6
Don't add up
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 26th May 2012, 04:54 PM   #6
Duplicated, sorry
Old 26th May 2012, 05:11 PM   #7
hello and thanks for your help!
R11 is 6,8v
R14 is 5v
Some more measurements are shown in the attached scheme
The 1 ohm resistors are between 0,45 an 0,43v
The four lateral heatsinks are rated Cº/W 0,11 each. Maybe I could help them with fans ;P
You are right Jacco, as soon as I can I'll measure again the 9610's
Ah! the loudspeaker I'm using its just for testing purpouses
Pd: sorry for my bad english
Old 26th May 2012, 05:41 PM   #8
it looks like a modushop 5U 500mm chassis. and they are rated 0.11C/W pr SIDE
and thats at 80C above ambient.
more realistic its about 0.15-0.16C/W pr side.
Old 26th May 2012, 06:12 PM   #9
measures source resistor:
Bias Board:
r-40= 0,534
r-41= 0,533
r-42= 0.421
r-43= 0,584
r-44= 0,499
r-45= 0,438
Output board
r-46= 0,497
r-47= 0,467
r-48= 0,526
r-49= 0,410
r-50= 0,558
r-51= 0,715
Thanks for your interest I'm desperate.
Old 26th May 2012, 06:37 PM   #10
Did you match the output devices or just throw them in ?
The 715mV is way off, but the others show +35% spread.
Iznogood
Aleph P Pics kilowattski Pass Labs 11 19th September 2004 11:39 AM
Aleph Ono Pics TheMyxin Pass Labs 15 17th August 2004 05:06 PM
Soundcard performace .......FFT pics and problems. A 8 Digital Source 18 9th July 2004 06:53 PM
Pics of Aleph 5 protos Pass Labs 22 21st October 2002 09:39 PM
Pics af my ALEPH 2 ndhennin Pass Labs 16 4th August 2002 09:25 AM
Copyright ©1999-2017 diyAudio
