Old 9th October 2003, 07:56 PM   #1
Default BOSOZ low output?
I've constructed the BOSOZ and the good news is that there is no smoke (I am always happy to get this far!). Anyway, I am using two Panasonic plastic pots at the output, valued at 10K. I chose not to match the transistors and at the moment I am using the amp as unbalanced.
The output seems very low, the volume pots work in that I can turn them all the way to the other end! However, these are the 4 pinned variety that I have not encountered. have I wired the pot wrongly? Also, the voltages on Drain is 31.4v and -4.3v on Source, Gate is grounded. R15 is 221 ohms, as I wanted to see how much gain we're playing with. Have I missed something?
Or is there a thread that someone could direct me to, as always advice is gratefully appreciated.
Cheers.
Brownlow
P.S. I got to start on the Aleph5 next...
Old 9th October 2003, 10:25 PM   #2
The one and only
Nelson Pass's Avatar
Often a 4 pin pot means that there is a fixed tap on the resistor,
and grounding it gives more of an audio taper than a linear
pot. You are free to ignore it, if that's the case.
Old 31st October 2003, 08:10 AM   #3
Kriss is offline Kriss  Poland
Hallo
Few days ago I hooked up first time my BoSoZ. First impression was probably the same. It works, works fine but output signal was low. It was about twice lower than directly from CD ( CD with variable output so I could compare system with or without aditional preamp betwen CD and amp). I approach gain by decreasing R15 to 100 ohm. The output level now looks OK. Music play on the same volum like directly from CD.
This experience push me to omit input/output pots and adjusting only the gain.
Krzysztof
P.S. My next pre will be clone Aleph P 1.7 in P2P configuration.
Old 31st October 2003, 11:26 AM   #4
wuffwaff's Avatar
Hello Kriss,
normally gain should be between 10 and 20 dB (x3,16 and 10x) depending on R15 so something must be wrong.
william
een ooievaar is geen konijn want zijn oren zijn te klein!
BOSOZ Output Waveform Question hifimaker Pass Labs 8 9th April 2007 01:34 AM
bosoz output level skaara Pass Labs 34 2nd October 2005 10:09 PM
Output stage/preamp with gain: X-Bosoz with diff.-pair? Onvinyl Pass Labs 1 19th July 2004 08:29 AM
x-BoSoZ volume on in or output yoke Pass Labs 9 24th June 2004 06:43 AM
What output capacitor value for BOSOZ macka Pass Labs 7 12th May 2004 08:00 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
