Balanced F5 in a Small Footprint
Old 23rd May 2012, 01:15 PM   #11
pcb121055 is offline pcb121055  United States
Wow! No laziness in you. Lots of good work. Small form factor is a great idea. Interested in the heat tunnel performance. Was there an analytical approach to determining size or was it guesswork? Target CFM, maybe?
Old 23rd May 2012, 01:51 PM   #12
lhquam is offline lhquam  United States
The size of the PCB was determined by 2 main factors:
1. The HeatsinkUSA E007 heatsink when cut in half is 7" x 5". Best MOSFET spacing becomes 3.5" x 2.5".
2. ExpressPCB offers a low cost ($85) prototype MiniBoard service for 2.5" x 3.8" boards. You get 3 custom boards for that price.
The cooling fan being used is a Noctua NF-S12B-FLX Noctua.at - sound-optimised premium components "Designed in Austria"! which can run at speeds between 600 RPM (49.2 m^3/h) and 1200 RPM (100.6 m^3/h). At 1200 RPM and 30W per MOSFET the heatsink temperature risees around 30C above ambient. I need to make additional measurements to verify the steady-state heatsink temperature vs bias current (watts) vs. fan voltage (RPM).
Old 23rd May 2012, 01:51 PM   #13
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
did I said Fugly! ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd May 2012, 04:02 PM   #14
I need to make a correction to information about the THD graphs. The bias currents were .8A, 1.2A, and 1.6A, NOT 1.0A, 1.5A, and 2.0A as previously posted.
Old 23rd May 2012, 07:02 PM   #15
cyclecamper is offline cyclecamper  United States
What's a good source for the aluminum heat tunnels?
Old 23rd May 2012, 07:21 PM   #16
I use HeatsinkUSA 10.080" Wide Extruded Aluminum Heatsink cut to 7" length. 10.080" Wide Extruded Aluminum Heatsink - HeatsinkUSA, LLC Store
For the heat tunnel, the heatsink is cut in half to create 2 heatsinks 5" x 7" x 2.5". The airflow direction is 7", the heatsink width is 5" and the fin height is 2.5".
Old 26th May 2012, 04:55 AM   #17
Default Listening results
I have been listening to the amplifiers described above for several days. There are 4 x F5 amplifiers of 2 x F5-balanced amplifiers depending on how you make the input and output connections.
Since one PCB is composed of FQP19N20C/FQP12P20 MOSFETs and the other of FQA28N15/FQA36P15 MOSFETs, listening to the two channels in balanced stereo might be questioned. I did listen to that combo and could not find anything to fault. Likewise, I have been listening to each board as a stereo pair of ordinary (unbalanced) F5s.
Speakers: B&W CDM1
Results:
Balanced: hum and noise absolutely inaudible with ear directly at speaker cone.
Unbalanced: hum and noise barely audible with ear directly at speaker cone.
Listening to a variety of Jazz (Charlie Byrd, Miles Davie, Stan Getz, Scott Hamilton, ...) at "normal" listening levels, I could find no fault with the sound quality, and no perceptible differences between the amplifiers. Maybe someone with better ears could detect a difference, but not me.
Old 26th May 2012, 05:07 AM   #18
Default Small footprint F5-Turbo
I have modified my V1.1 circult board to support the F5-Turbo diodes.
The modified board will support the following:
1. 1 x Balanced F5
2. 2 x Unbalanced F5
3. 1 x Balanced F5-Turbo-V2 with single MOSFET
4. 2 x Unbalanced F5 Turbo-V2 with single MOSFET
5. 1 x Unbalanced F5 Turbo-V1 with 2 MOSFETs
6. 1 x Unbalanced F5 Turbo-V2 with 2 MOSFETs
Old 26th May 2012, 05:55 AM   #19
qusp is offline qusp  Australia
qusp's Avatar
coolness! i'll keep watching the thread, i'll volunteer to test out the balanced headphone amp version, should be able to get away with passive heatsinking for that with a reasonably small heatsink
Old 26th May 2012, 08:19 AM   #20
Melon Head is offline Melon Head  Australia
Banned
Love the heatsink and fan arrangement.
Balanced F5 in a Small FootprintHide this!Advertise here!
small footprint speaker for kick bass BigBoned Subwoofers 12 24th October 2011 01:30 AM
Small footprint SUB using multiple small drivers FredrikC Subwoofers 5 29th August 2010 05:01 AM
Small footprint SUB using multiple small drivers FredrikC Subwoofers 0 25th August 2010 08:12 PM
First time horn help.. small footprint Matt@Nearfield Multi-Way 2 17th May 2005 02:55 PM
