oneplustwo Aleph X build thread - Page 17 - diyAudio
Old 26th February 2013, 04:49 PM   #161
oneplustwo's Avatar
@Eric: Graeme helped me with matched 9510s for which I believe I still owe him beer. Hopefully at burning amp this year. These were from his units before he upgraded himself.
@6L6: yes, I'm considering reusing the trafo/rectifier/etc part of my F5 for the F4. Question is whether it makes sense to do so based on the risk that I would ever sell one of them. My guess is no so ill probably go for it. The other thought which I've never seen done is using the same heat sinks! I'd probably use a heavy switch for the PSU connections and have separate input and outputs. But I'm not sure it's worth the risks. It would eliminate a huge majority of build costs though! Anyone seen this done before?
My Projects
Old 26th February 2013, 04:56 PM   #162
6L6 is offline 6L6  United States
6L6's Avatar
The only issue I see with sharing heatsinks is that you would want the amp boards not in use to be completely removed electrically -- instead of a switch you would want your non-permanent connections to be on a screw terminal block or barrier of some kind.
Old 27th February 2013, 06:00 AM   #163
oneplustwo's Avatar
Turns out its actually an F1. Oops. And they won't fit on my F5 sinks. But they might fit on my aleph sinks. More to think about. And perhaps appropriate since this is an a
Aleph thread after all.
My Projects
Old 27th February 2013, 07:22 PM   #164
gl is offline gl  United States
I had forgotten about that beer! See the second pic in the bottom row.
The Burning Amp Festival- an Audio Happening
That's you in foreground WITH A BEER. That's me behind you WITHOUT A BEER.
I look forward to making this right!
Graeme
Old 27th February 2013, 07:33 PM   #165
oneplustwo's Avatar
HA! No denying it... photo proof is there for all to witness. My excuse is that I wasn't thinking clearly after schlepping the big Sunflower speakers up the stairs. This year for sure!
My Projects
Old 14th April 2013, 02:33 PM   #166
2bz is offline 2bz  United States
Sorry if this has already been asked/answered but what is the source for the PCBs? Thanks.
Old 14th April 2013, 06:53 PM   #167
oneplustwo's Avatar
eBay. I got the from another member and then made my penance donation to diyaudio.
My Projects
Loudspeaker Build Thread Hsmeets Multi-Way 67 15th August 2012 02:30 PM
oneplustwo F5 build thread oneplustwo Pass Labs 251 30th May 2012 10:36 PM
oneplustwo DCB1 Black, White and Red build thread oneplustwo Pass Labs 1 26th February 2012 07:11 AM
aikido build thread- nate Tubes / Valves 1 27th February 2009 06:01 AM
Dan's Aleph Build Thread monarodan Pass Labs 19 14th February 2007 12:06 PM
Copyright 1999-2017 diyAudio
