#131 |
desolder (pull out ) either R29 od R47 and then try entire procedure again
something is wrong with your measurement - voltage across R29 and R47 must be the same
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#132 |
1.21 Gigawatts?!
Doh! Sorry, fat fingered one number.
D5: 8.92V R47: 4.83V R29: 4.84V R30: 3.0V
My Projects |
#133 |
1.21 Gigawatts?!
Slightly different numbers after an hour of warm up if it makes a difference:
D5: 8.99V R47: 4.98V R29: 4.99V R30: 3.1V During this commercial break... can I also confirm that it's important to turn on your source BEFORE turning on the amps? I noticed some pretty big turn on thump when I didn't initially have my source already one. Woofers extended outward pretty far... scared me a little bit but doesn't seem to have done any damage.
My Projects Last edited by oneplustwo; 15th January 2013 at 06:33 AM. |
#134 |
just do what I wrote in #131
regarding thump - that's normal , it doesn't have anything with your amp , but with common logic
#135 |
1.21 Gigawatts?!
Great, I'll give that a try tonight. Thanks for your help! I'm not really sure why both resistors are there in the first place... perhaps just power handling so as to not require higher wattage resistors? Or perhaps for people like me who just need an easy way to get to zero absolute DC offset?
My Projects |
#136 |
dunno ;
someone was keen to put plenty of parts , probably to invoke better sound ? ![]() properly sized R30 and Rp1 are all you need there , covering all possible variations
#137 |
1.21 Gigawatts?!
Removed R47 and now when I turn the pots the OTHER direction fully, I can only get to +2.5 and +1.5 V. So it looks like I need to add another resistor back in. I should be able to find something in the ballpark. Any suggestions? Maybe something in the 100R range?
Also, I noticed the heat distribution is backwards now... although much more even now.
My Projects Last edited by oneplustwo; 17th January 2013 at 12:47 AM. |
#138 |
what +2V5 and what +1V5 ?
edit : I'm going to sleep now read ya tomorrow
#139 |
just thinking
if you now have out to gnd offset in positive (instead of previous negative ) , just put R47 back but - this time not 475R ; put 1K for start then - if necessary - 910R or 820R good night .....
#140 |
1.21 Gigawatts?!
Yes, that was what I was thinking. I'll try 1K first as you suggested. Thanks!
BTW, after fully warmed up, I have 1.6V and .3 V (positive on both) now. Seems to not be drifting anymore.
My Projects |
| Loudspeaker Build Thread | Hsmeets | Multi-Way | 67 | 15th August 2012 01:30 PM |
| oneplustwo F5 build thread | oneplustwo | Pass Labs | 251 | 30th May 2012 09:36 PM |
| oneplustwo DCB1 Black, White and Red build thread | oneplustwo | Pass Labs | 1 | 26th February 2012 06:11 AM |
| aikido build thread- | nate | Tubes / Valves | 1 | 27th February 2009 05:01 AM |
| Dan's Aleph Build Thread | monarodan | Pass Labs | 19 | 14th February 2007 11:06 AM |
