oneplustwo Aleph X build thread
Old 19th May 2012, 11:07 PM   #21
AudioSan is offline AudioSan  Norway
Originally Posted by oneplustwo View Post
Hmm. How about the rustoleum high temp grill paint stuff. Would that work?
never tryed it. but its hard to get a nice thin coat betwin the fins. powder coat is easy that way.
high temp paint also have to be baked in a owen. or it just falls off.
Old 20th May 2012, 03:01 AM   #22
oneplustwo is offline oneplustwo  United States
oneplustwo's Avatar
I'm going to see how much the par metal ones are at 8" long. At least they're anodized. And I actually think the fin spacing is ok despite being better suited for forced air. The benefit of additional surface area will offset that to some degree as well. Also, I may just end up adding some sort of fan base anyway. The pros out weigh the cons more easily given the high proportionate cost of heat sinks in this build. That said, perhaps I'll just go with the stock 5" heat sinks if the fan base becomes more of a likelihood in my mind.
My Projects
Old 20th May 2012, 03:49 AM   #23
oneplustwo's Avatar
Also, can I use wirewound resistors for the 5W 1R resistors? Maybe this one.
It will be a tight fit on my board width wise but I stagger them top to bottom.
Otherwise, I can get these metal oxide ones. They're a little long though.
My Projects
Old 20th May 2012, 05:51 AM   #24
oneplustwo's Avatar
After some research, I think the fin spacing is ok. The table claims minimum fin spacing of 6.5mm for 75mm long fins. The par-metal sinks I want are spaced at 7.1mm and the fins are only 48mm long.
Separate question... anyone have source for matched IRF9610s? I think I just need 2 pairs matched. The third one doesn't have to match, right?
My Projects
Old 20th May 2012, 11:08 AM   #25
i also use wirewound resistors for CRC. thats fine.
i think h_a can supply matched 9610's and yes, you need 2 pairs the third don't need to be matched.
Old 21st May 2012, 04:22 PM   #26
oneplustwo's Avatar
h_a doesn't have 9610s after all. I'll probably just buy a dozen and try matching myself. Seems worth the effort and would be a good learning experience.
Any suggestions on a source for the 2SC2240? Not sure if the ebay sellers are reliable or not.
My Projects
Old 21st May 2012, 08:15 PM   #27
oneplustwo's Avatar
Looks like some BOMs use the BC550C instead of the 2SC2240. I couldn't find any rationale or pros/cons though. Is the BC550C ok? I think I have a ton of these lying around from some of my Amb headphone amp projects.
My Projects
Old 21st May 2012, 09:53 PM   #28
you can also use BC546.
just use what suits you. just be watch the leg posisions
i use BC546 for my aleph2's and aleph30
Old 21st May 2012, 09:56 PM   #29
strange that h_a did not have the 9610's. hmmm. maybe mouser sell matched pairs?
Old 21st May 2012, 09:58 PM   #30
oneplustwo's Avatar
Cool... I think I have some of those lying around too!
My Projects
oneplustwo Aleph X build threadHide this!Advertise here!
Loudspeaker Build Thread Hsmeets Multi-Way 67 15th August 2012 01:30 PM
oneplustwo F5 build thread oneplustwo Pass Labs 251 30th May 2012 09:36 PM
oneplustwo DCB1 Black, White and Red build thread oneplustwo Pass Labs 1 26th February 2012 06:11 AM
aikido build thread- nate Tubes / Valves 1 27th February 2009 05:01 AM
Dan's Aleph Build Thread monarodan Pass Labs 19 14th February 2007 11:06 AM
Copyright ©1999-2017 diyAudio
