oneplustwo Aleph X build thread
Old 13th January 2013, 07:07 AM   #121
oneplustwo is offline oneplustwo  United States
oneplustwo's Avatar
Ok, here's a quick update...
SECOND CHANNEL:
I got the second channel put together but without the new rectifiers (haven't arrived yet.) However, I did add some heat transfer compound between the rectifiers and the sinks. That was... tricky since I didn't want to desolder and resolder the sinks and rectifiers. But I was able to access the trapped screws through the holes of the sinks in front of them. In any case I got it done, buttoned it back up, and voila! It works. They still get really hot AND they aren't smoking. Also, I measured ripple and it's a solid 17mV. No caps on the rectifiers. I figure they're rated for 15A so we'll use them unless I have good reason not to in the future.
We're still clearly in break in mode but it plays music quite nicely.
On DC offset, relative DC offset (+ to -) is still zero and absolute offset is about 7.7V. That's with the pot maxed out.
FIRST CHANNEL:
Speaking of absolute offset, for channel one, I adjusted VR2 to the max and get output to ground at 10V when warmed up. Can't get any lower than that. Relative DC offset from output + to - is essentially zero. Ripple is still solid at 18mV or less. Furthermore, I hear absolutely nothing from the speakers with no signal so I'm not worried about the ripple at all. The only sound I hear is a tiny bit of transformer hum.
Here's a pic of my temporary setup. Right now, path is macbook --> Emotiva XDA-1 --> hotrodded DCB1 --> Alephs.
Sounds quite good actually already. Effortless is the best work I can think of at the moment. Lots of caveats of course... clearly biased, don't have golden ears, room setup is terrible, etc.
Thanks to everyone for their help. Special shout out to gl for the differential pairs!
Once I get my function generator, I'll play around with testing.
My Projects
Old 13th January 2013, 12:12 PM   #122
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
so one half will have 10V x Iq less dissipation , while other will have for same amount more dissipation
having both offsets zeroed ( after temp equilibrium) is a must
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th January 2013, 03:27 PM   #123
oneplustwo's Avatar
Hmm. Ok. I'll try to find a trimmer pot with more range to get to zero then. Thx!
My Projects
Old 13th January 2013, 03:51 PM   #124
Zen Mod's Avatar
gimme exact schm you're using and I'll tell what to change
also put here exact value of offset between outputs and gnd , is it positive or negative
Old 13th January 2013, 05:45 PM   #125
oneplustwo's Avatar
I get negative 8 and 10V for the two channels.
Here's the schematic.
And the BOM:
My Projects
Old 13th January 2013, 05:53 PM   #126
Zen Mod's Avatar
exact values for D5, R47,R29,Rp1 and R30
I presume that you set Rp to max (verify , please , with amp off) , and you can't out-gnd offset zero
how's that - you wrote somewhere in previous posts that both offsets are near zero , and now out-gnd offset is suddenly not ?
Old 13th January 2013, 05:58 PM   #127
oneplustwo's Avatar
Sorry for not being clear. The dc offset from + to - was always zero. The dc to ground has always been near 10V.
I will confirm rp1 when I get home. But 99% sure it was fully counter clockwise.
My Projects
Old 13th January 2013, 06:10 PM   #128
Zen Mod's Avatar
Originally Posted by oneplustwo View Post
....... The dc to ground has always been near 10V.
that was exactly what I asked in first reply , after your post about dissipation difference
S......
that means nothing - it depends how you mount it - can be full value , or full zero ; that's why I asked for confirmation with ohm-meter
Old 14th January 2013, 07:17 AM   #129
oneplustwo's Avatar
ZM - sorry, I should have made my post #120 more clear. In any case, at the risk of overstating... output to ground is -8 and -10 for each amp.
Also, I'm confirming the value of RP1 is at full value while counter-clockwise. I'm reading 150R while in place measuring at the points where R29 and R30 connect to it. When turned to full clockwise, it's zero.
The 150R reading confirms its roughly a 200R pot if I calculate the parallel resistances from R29, R30, and R47.
Are you also looking for the voltages across each of the items you mention above? Or just their part values?
If so... here they are:
D5: 8.92V
R47: 3.83V
R29: 4.84V
R30: 3.0V
Thanks in advance for your help!
My Projects
Old 14th January 2013, 08:01 AM   #130
oneplustwo's Avatar
Also, in case you couldn't read the PDF:
200R:Rp1
475R:R29
330R:R30
475R:R47
My Projects
oneplustwo Aleph X build threadHide this!Advertise here!
Loudspeaker Build Thread Hsmeets Multi-Way 67 15th August 2012 01:30 PM
oneplustwo F5 build thread oneplustwo Pass Labs 251 30th May 2012 09:36 PM
oneplustwo DCB1 Black, White and Red build thread oneplustwo Pass Labs 1 26th February 2012 06:11 AM
aikido build thread- nate Tubes / Valves 1 27th February 2009 05:01 AM
Dan's Aleph Build Thread monarodan Pass Labs 19 14th February 2007 11:06 AM
