oneplustwo Aleph X build thread
Old 6th January 2013, 01:42 AM   #101
6L6 is online now 6L6  United States
6L6's Avatar
The .22 value comes from a conversation with Wayne Colburn of Pass Labs who said that it was the sweet spot -- just one .22 across the AC worked as good or better than individual caps across each diode.
Regardless, using the .1 across the AC is still going help. Go ahead and use them, I like using what's on hand as well!
If you have a scope, clip it in and take a look. If you don't have a scope, I highly suggest getting one. It's awfully useful for this hobby.
Old 6th January 2013, 01:56 AM   #102
PKI is offline PKI  United States
PKI's Avatar
.22 -- magic? :-) What about .47, that's what I am using?
Old 6th January 2013, 02:02 AM   #103
oneplustwo is offline oneplustwo  United States
oneplustwo's Avatar
I actually did pick up a Rigol scope a little while ago. Last used it when I was tweaking my F5 so this will be a good excuse to fire it up. Umm... what exactly would I be looking for?
I'll try the .1, then 1.0, and whatever else I might be able to find in that range. Try to find my own sweet spot.
My Projects
Old 6th January 2013, 02:39 AM   #104
6L6's Avatar
I think you can get too big... Most snubbers you see out in the world are 0.1uf or thereabouts. 1.0uf seems big, glancing through forum discussions on the topic.
Old 6th January 2013, 03:39 AM   #105
oneplustwo's Avatar
Interesting read: http://www.hagtech.com/pdf/snubber.pdf
From here: What are the advantages of full wave bridge rectifier with capacitors parallel to diodes? - Electrical Engineering
And here: http://www.diyaudio.com/forums/solid...ifiers-do.html
I think I have some smaller Kemet caps used as in the last link on my beta24 (of which I still have to trouble shoot one channel). Might have those lying around.
To answer my own question above, I assume I'm just looking for amount of ac that gets through the psu while the amp is warmed up and playing music?
My Projects
Old 6th January 2013, 06:08 AM   #106
oneplustwo's Avatar
I mean ac ripple.
My Projects
Old 6th January 2013, 06:43 AM   #107
qusp is offline qusp  Australia
qusp's Avatar
no, its not a less than critical part, wrong snubber value on a fast rectifier part could easily mean resonance and resonance on the supply rails can mean oscillation
Old 6th January 2013, 07:19 AM   #108
oneplustwo's Avatar
Fair enough! I was just thinking that getting in the ballpark would be beneficial even if not totally optimized. And since I can't measure stuff as in the article I guess I'll just have to try things out. Seems like I can probably start with values a bit less than 0.1uF and move up to from there to see if I can get at least a local optimum.
My Projects
Old 6th January 2013, 07:31 AM   #109
qusp's Avatar
how critical it is will depend on the exact rectifier parts you are using, if you are using SIC zero recovery parts then it becomes quite important and without measurement I wouldnt recommend just trying stuff out. the AX can be a bit touchy already really cant it? I would say anything between 10-100nF would be a good place to start, 1uf is too large IMO
Old 6th January 2013, 07:49 AM   #110
oneplustwo's Avatar
On my beta24, I have four caps from the ac to dc terminals as opposed to one across the ac terminals. Any benefit to that configuration?
My Projects
oneplustwo Aleph X build threadHide this!Advertise here!
Loudspeaker Build Thread Hsmeets Multi-Way 67 15th August 2012 02:30 PM
oneplustwo F5 build thread oneplustwo Pass Labs 251 30th May 2012 10:36 PM
oneplustwo DCB1 Black, White and Red build thread oneplustwo Pass Labs 1 26th February 2012 07:11 AM
aikido build thread- nate Tubes / Valves 1 27th February 2009 06:01 AM
Dan's Aleph Build Thread monarodan Pass Labs 19 14th February 2007 12:06 PM
