#2 |
Dat cat's got them voodoo eyes....!!
Too bad we can't see the F5 heatsinks with more definitive detail......... |
#3 |
So, I would guess you were looking at an aluminum (natural) surface behind the board? It shows cold. Natural shinny metal surfaces do not reflect proper emissivity for an IR camera. You will need to put something like a spot of thermal silicone goop on the shinny metal and read the temp of the goop. Unless you have black anodizing.
It also looks better if you adjust your low and high Limits to something normal like 25 -85C. Room temp would be black and 85 would be white.
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss Last edited by flg; 14th May 2012 at 10:05 AM. |
#4 |
that cat needs bigger heatsinks
#6 |
#7 | |
What I do see is a heat producing component to the left of, but just below the level of the tansistor, most likely under the board though? What's that a source R? Only 1? This is a very good tool for optimising, if you have access to one. Also for deguging problems!
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#8 | |
I'll put some silicone goop at various places on the heat sink, and re-image it. Just for all your information, the heat sink is a 10x12, with 2" fin. I was hoping to get both F5 channels on a heat sink of this size. Right now (for testing purposes) I have a single channel mounted in the center of the right half-side of the heat sink. I don't think it will work, and I'll just stick with one channel per 10x12", unless I got to some active cooling. |
#9 |
#10 |
Hahaha.......
I have a planter outside my front door, one of the neighbours cats LIKED to relive its self in there, till i doused its 'lurking evil' with a pail or 'holy dishwater'. ......or did it become the first liquid cooled cat? |
| 1M-F5 - A 1 MHz F5 project | triode_al | Pass Labs | 43 | 25th October 2012 08:28 AM |
| F5 Cascoded - an alternative for my interest in the Balanced F5 | NYCOne | Pass Labs | 159 | 24th March 2011 05:23 AM |
| Biasing/thermal compensation of Thermal Trak transistors | Bob Cordell | Solid State | 156 | 11th December 2010 08:38 PM |
| help with Thermal Impdeance vs. Thermal Conductivity | Eric | Pass Labs | 4 | 22nd July 2005 07:23 PM |
