My F5T V3 build - Page 9 - diyAudio
Old 26th October 2012, 02:06 PM   #81
Marra is offline Marra  United Kingdom
The 2.2k resistors are as shown on the FistWatt power supply schematic at the bottom of this link.
http://www.firstwatt.com/pdf/prod_f5_man.pdf
Its how I built my F5 and there have been no problems.I haven't built an F5 turbo yet.
Old 26th October 2012, 03:52 PM   #82
I'm going to have to look to be sure, I may have tacked some onto the Daniel's PS boards I used....I just dont remember.
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 26th October 2012, 04:07 PM   #83
Rush is offline Rush  United States
Those resistors are good practice incase outputs are not turned on in initial power up and power down testing.
They are cheap and Mr. Pass doesn't know how a DIYer will set up his amp, maybe with a power supply in a separate case and a detachable cord to output case. A bleeder would be mandatory then.
We are talking about F5T V3 with in excess of 50 volts per rail.
Why not have bleeders?
Rush
Old 26th October 2012, 04:53 PM   #84
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Russellc
Peter Daniels boards did not have bleeders, you had to put them across the caps on the underbelly.
The ones I made up do.
Salas Boards GB 2017#1 ON ORDER | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards On ORDER
Old 26th October 2012, 05:14 PM   #85
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
What happens if you don't have?Practically I mean? Is it bad for the caps, for example?
Old 26th October 2012, 05:16 PM   #86
Yes, Iremember being told that, I just cant remember if I followed through!
Russellc
Old 26th October 2012, 06:17 PM   #87
bobodioulasso's Avatar
The amp doesn't care but your fingers might have to.
Old 26th October 2012, 06:17 PM   #88
No, not bad for caps, they will eventually drain down due to internal resistance.
Bad for you when you grab the rail voltage inside the amp you see is unplugged and find 100 volts across the rails, much to your dismay!
I have been shocked with a tube amp with 400 volts and I was dismayed! I had one hand in my pocket though, so I am still here to talk about it. I actually forgot it was turned on while I had it upside down. Bleeders don't replace good common sense.
Rush
Old 26th October 2012, 08:14 PM   #89
Yes, my P-P 6550/KT-88 tube amp has 600+ on the rails, and it will play for a short while after power down, the caps hold so much juice.
I think the point Andrew is making is that with these Class A amps, they draw full current all the time, and on switch down they drain VERY quickly? Or I think that's what he means, post #67, #71 and #75.
Russellc
Old 26th October 2012, 08:21 PM   #90
Tea-Bag's Avatar
bleeders are cheap insurance against some scenarios.
F5T Premium kit GB buzzforb Group Buys 650 26th May 2017 09:01 AM
GB for F5T Convertible amplifier boards Tea-Bag Group Buys 127 13th July 2014 06:48 PM
V3 trident coolhead Twisted Pear 7 14th March 2012 02:18 PM
Lepai V3 with TDA8566 Electro-Chip Chip Amps 4 3rd January 2012 05:04 PM
LAB Subwoofer v3.0 hulkss Subwoofers 3 23rd May 2004 08:27 PM
Copyright 1999-2017 diyAudio
