Old 26th October 2012, 10:20 AM   #71
What is the current draw of the ClassA amplifier?
Now at the instant you pull the mains plug from the mains supply socket, what is the current draw of the ClassA amplifier.
Now take a guess at how slowly, or how quickly the smoothing capacitors will discharge.
Why do you need to add extra resistors to draw more current from the PSU?
Put your thinking cap on.
Old 26th October 2012, 11:06 AM   #72
flg is offline flg  United States
flg's Avatar
Bleeders are still a good safety measure. let's say the amp needs trouble shooting? You are not garunteed the supply will discharge it's caps and could get burnt, blinded, etc. It's only a few mA extra draw vs. Amps for the output section.
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 26th October 2012, 11:13 AM   #73
so good? I have never seen the need for them and despite my reputation for safety have never used them.
I have looked at relay connected discharge resistors that ONLY connect AFTER power down. That is a quite different topology.
Old 26th October 2012, 11:21 AM   #74
"I have looked at relay connected discharge resistors that ONLY connect AFTER power down. That is a quite different topology."
Like?
Old 26th October 2012, 11:25 AM   #75
They don't conduct while the amp is operational.
They don't get warm/hot.
They don't increase current draw.
They do conduct when required.
They do discharge high voltage capacitors in a controlled way.
I even bought lots of 24V tungsten bulbs to gain some advantage in non linear resistance characteristic as the capacitor voltage drops.
Old 26th October 2012, 11:31 AM   #76
No, I meant do you have an example of a circuit. I haven't seen something like that so far.
Old 26th October 2012, 01:35 PM   #77
I never thought of it that way but it explains a lot. On my Tube amps with large power supplies or various Class A/B amps, I would always wait a period of time after switching off the power amp before switching off the pre amp. As they would continue to play after switch off otherwise, I always thought this was a good idea for bleeder resistors. With the F-5, I always noted it was "Dead" immediately with switching it off, and immediate switching off of the preamp caused not a sound.
I would imagine it bleeds off almost immediately. I have noted several have noted in F-5 builds these bleeders werent necessary, now I know why.
Russellc
Pass DIY B-1, Pass DIY F-5
Old 26th October 2012, 01:48 PM   #78
Boscoe is offline Boscoe  United Kingdom
I wouldn't have said it was exactly hard...
Drive the relay with the secondaries of the transformer which switch the caps power to the amp or through the bleed resistors. This gives a much more controlled power down of the amps too and eliminates the possibilities of one rail draining faster than the other.
I thought about it once, but then thought again.
Old 26th October 2012, 01:57 PM   #79
"Oh really?"
Well have you done it?
Old 26th October 2012, 02:00 PM   #80
"Oh really?"
What's your problem I'm trying to help!?
F5T Premium kit GB buzzforb Group Buys 569 Today 12:34 AM
GB for F5T Convertible amplifier boards Tea-Bag Group Buys 113 4th May 2013 03:43 AM
V3 trident coolhead Twisted Pear 7 14th March 2012 02:18 PM
Lepai V3 with TDA8566 Electro-Chip Chip Amps 4 3rd January 2012 05:04 PM
LAB Subwoofer v3.0 hulkss Subwoofers 3 23rd May 2004 08:27 PM
Copyright ©1999-2013 diyAudio
