Old 17th May 2012, 10:19 AM   #41
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
all you need is to listen carefully , and you'll hear the KLUNK!
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 17th May 2012, 11:00 AM   #42
Dimitris
dimkasta's Avatar
Buzz from my understanding, the diodes only affect the maximum amperage that can be fed into the mosfets (obviously in max AB operation).
The class A operation usually ends after the 2xBiasAmperage is reached, which is normally way bellow even than the vanila F5 max amperage.
Again from my understanding, if you want to increase the Class A range, you have to increase the bias and use bigger heatsinks (and maybe bigger passive components)
Old 17th May 2012, 11:10 AM   #43
buzzforb's Avatar
I beleive that you are correct. Just like that official stamp!
Problem is, I can get mine to KLUNK with just one pair.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 17th May 2012, 11:46 AM   #44
AndrewT is online now AndrewT  Scotland
Set the Vrs bias voltage to say 100mVdc. We can scale from this starting figure later.
With a 0r2 value for Rs the bias current will be 0.5Adc.
When the amp is operating with an 8r0 load and delivering 0.5Aac to the load, the output devices are passing AC waveforms that vary about that 0.5A starting value by +-0.25A*sqrt(2) = 0.35A, resulting in a sinusoidal current ranging from 0.15Adc to 0.85Adc. The current flow does not reverse so we are still dealing with DC as far as each output device is concerned.
Now increase the load current to 0.7071Aac, for which the maximum value is 1Apk (for a sinewave).
The device currents now range from 0Adc to 1Adc. While one device is not passing (0Adc) the other device is passing maximum current (1Adc) and all of this current passes to the load. Note the load in this case is the parallel combination of the external 8r0 test resistor and the internal feedback resistors and any Zobel and such like, if fitted.
The voltage across the Rs also varies with the load current. Vrs ranges from 0mVrs to 200mVrs for that 0.7071Aac of load current.
Now let's look at the transition to the region beyond ClassA. Let's output a current to a test load of 1Aac, requiring a maximum output of 1.414Apk to the load.
The device currents now range from 0mAdc to 1.414Adc. But they are no longer sinusoidal. There are periods during the waveform cycle where one device is "off" and the other device is controlling the output current alone with no help from it's complementary partner. The Vrs is now ranging from 0mVdc to 282.8mVdc.
Let's insert that parallel diode to bypass the Rs, if required.
The voltage across the diode for all the above operating currents varies from 0mVdc to 282.8mVdc. Looking at the Id vs Vf graph you will find that the diodes bypasses a virtual zero current.
Now we come to scaling that starting value for the bias voltage.
Let's double Vrs from 100mVrs to 200mVrs.
I am going to stop and ask you to go back through that previous description of the operation and fit in the new values of currents and voltages for this new starting condition. I will call this part II.
If anybody gets stuck I will type up the repeat description modified to reveal the part II values.
There will be a part III.
Old 17th May 2012, 03:30 PM   #45
buzzforb's Avatar
Excellent and thorough, Andrew. I am sure everyone greatly appreciates your time. The smart ones will take them time to work through the math. If memory serves me, the AC voltage variation across my Rs in the single pair version rarely exceeded 100mV.
Old 18th May 2012, 09:37 AM   #46
I hope there were no mistakes in my description. No one has shouted at me yet.
Old 18th May 2012, 09:58 AM   #47
Dimitris
dimkasta's Avatar
I will try to put that in excel later today and post it for everyone to keep for their experiments
Old 18th May 2012, 09:59 AM   #48
It's simple arithmetic done in your head.
You don't need a maths simulation programme.
Old 18th May 2012, 10:17 AM   #49
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Can I change that with a scope input of 10V? I know now to put a cap in front of it!
I too would be interested in a simple mans formula for maxxing the F5T out from a signal perspective to get the diodes to dance.
Salas Boards 2013 #2 CLICK HERE | F6 Covertible PCB GB Boards Available |DCB1 boards and KITS available PM|SemiSouth R125, R100, R100A Available CLICK HERE |F5TC Boards Sign UP CLICK HERE
Old 18th May 2012, 10:21 AM   #50
buzzforb's Avatar
It shouldnt take too much. I am going to try to get my sound card working this weekend and run a known quantity sine wave through the amp to see what happens. If the sound card maxes out, ill just run it through my pre to amplify the signal. Waiting to hear the klunk!
F5T Premium kit GB buzzforb Group Buys 583 13th June 2013 02:37 AM
GB for F5T Convertible amplifier boards Tea-Bag Group Buys 113 4th May 2013 03:43 AM
V3 trident coolhead Twisted Pear 7 14th March 2012 02:18 PM
Lepai V3 with TDA8566 Electro-Chip Chip Amps 4 3rd January 2012 05:04 PM
LAB Subwoofer v3.0 hulkss Subwoofers 3 23rd May 2004 08:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
