My F5T V3 build
My F5T V3 build
Old 12th May 2012, 01:54 PM   #11
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
My F5T V3 build
higher OLG , higher amount of feedback
most likely different THD spectra
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th May 2012, 02:10 PM   #12
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Thanks. ZM. I was being too narrow minded in my view of operating conditions. Although the ratio of feedback is the same, more devices provide more gain, thus more is thrown away through feedback. Got me a soundcard. Actually can see what is happening with distortion now. I will have to pull the fets and mesure single vs double. Thanks again.
...Shape the sound , Man!
Old 12th May 2012, 02:30 PM   #13
Rush is offline Rush  United States
Originally Posted by buzzforb View Post
Rhetorical question, I presume. 400mV across bothe Rs. Roughly 3.2 A available bias with dual vs 1.6A with single pair. While i understand that more current is available, lets assume i never need more than 1A of current to drive my speakers to deafining levels. Why would two pairs ound better than one?
I am a firm believer we hear the power supply. Are you using the same volts and amp transformer for both? Same caps? If not, that could be the difference alone.
Rush
Old 12th May 2012, 02:50 PM   #14
buzzforb's Avatar
Yes. I have dual trafo, with CRC 54KuF before R, 54KuF after. ZM's explanation is quite true now that look through those lenses. Maybe I can get the soundcard up and running and have some visual aids to add to what I am hearing.
Old 12th May 2012, 03:13 PM   #15
That is great news, you are in a unique situation to have only the number of output devises as the lone variable.
I am excited to hear more from you on this.
Rush
Old 12th May 2012, 05:21 PM   #16
Hu B,
are you able and willing to reduce the 2pr bias to less than 3.2A?
Maybe try 2A (1A/pr) or even 1.6A (800mA/pr).
This last bias would be capable of the same maximum ClassA output current as the 1pr version. This could sound the same, or it could sound different.
I am not sure if the 3.2A & 1.6A stated in post10 are bias currents or maximum ClassA output currents.
regards Andrew T.
Old 12th May 2012, 10:33 PM   #17
buzzforb's Avatar
They are maximum class A cuurents. Earlier in the thread I stated that I was dropping around 400mV across the source resistors. My build is 100% experimental. If you want to try it, let me know and we will give it a shot. I am hoping to produce measured results to correspond with each change.
Old 13th May 2012, 02:47 AM   #18
a.wayne is offline a.wayne  United States
Sin Bin
4pr please ....
Old 13th May 2012, 11:01 AM   #19
In which case state the Rs for 400mVrs and state 3.2Apk or 1.6Apk, rather than 1.6Adc or 800mAdc as quiescent bias current options.
regards Andrew T.
Old 13th May 2012, 08:22 PM   #20
buzzforb's Avatar
Thanks for the correction Andrew. Haven't got much done today. went camping with family for Mothers Day. Hope to use upcoming week to get measurements on individual fets used as well as on single pair output. Matching for the GB will begin as well. Beta builders should get their fets soon. I will probably place the large order this week for the diodes and fets. I am going to give the kits another couple of weeks before ordering. Sorry for no updates.
I would like to display my ignorance again and ask about how ripple current ratings relate to PSU capacitance levels. Does having a capacitor with much greater ripple capacity reduce the amount of capacitance needed. I have always viewed the problem in F and V, not considering the current rating of the caps, as this is usually in line when appopriately sized caps are used. For example, a PEH200 63V 10000uF has the ripple rating of 2 - 22,000 63V Panasonic
My F5T V3 buildHide this!Advertise here!
F5T Premium kit GB buzzforb Group Buys 650 26th May 2017 10:01 AM
GB for F5T Convertible amplifier boards Tea-Bag Group Buys 127 13th July 2014 07:48 PM
V3 trident coolhead Twisted Pear 7 14th March 2012 03:18 PM
Lepai V3 with TDA8566 Electro-Chip Chip Amps 4 3rd January 2012 06:04 PM
LAB Subwoofer v3.0 hulkss Subwoofers 3 23rd May 2004 09:27 PM
