3-stage Pass Inspired Amp
Old 10th May 2012, 10:16 PM   #1
Dura is offline Dura  Canada
Default 3-stage Pass Inspired Amp
I have been reading Pass's article on DIY Op-amps and like one of his circuit examples (FIG 13): a JFET differential pair -> JFET volt amp -> MOSFET single ended or push-pull follower power stage (see attachment). I'm not sure the circuit will work as drawn as I merged 2 of Pass's circuits. Perhaps I should stick to some of Pass's single stage circuits.
Brock
Old 11th May 2012, 04:04 AM   #2
godfrey is offline godfrey  South Africa
A couple of corrections:
  • The output MOSFET must be N-channel, not P-channel.
  • The JFET at the top should be P-channel and connected the other way up.
  • You don't need the 1 Ohm resistor or the top 8 Ohm resistor.
  • You need to add a resistor (e.g. 2.21K) between the 22.1K feedback resistor and ground. Add a capacitor (e.g. 100uF) in series with it.
Old 11th May 2012, 08:46 PM   #3
Thanks for taking the time to correct some of my errors. Here is the revised circuit
Brock
Old 12th May 2012, 10:31 AM   #4
R.I.P.
What Vds is applied to the 389?
How much will this Vds vary when signal is processed?
The 389 are operating @ Id~2mA, what Idss do you plan to choose?
regards Andrew T.
Old 12th May 2012, 07:41 PM   #5
I'm not familiar with the 389 or any transistors for that matter. I was thinking of using mpf102s at a few mAs. I know the mpf102s can handle up to 25V and I'm not sure if that would be exceeded in the differential pair. I may not know enough to get the circuit to work, which is why I asked for help.
Brock
Old 13th May 2012, 09:35 AM   #6
R.I.P.
What current is passing through the 1k6 Drain load?
What is the voltage on the Drain?
What is the Vgs at the Id?
What is the voltage of the Source?
What is the quiescent Vds?
regards Andrew T.
Old 13th May 2012, 09:05 PM   #7
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
It will get a lot more practical if all three resistors to the negative
rail are replaced by constant current sources.
3-stage Pass Inspired AmpHide this!Advertise here!
Nelson Pass inspired headphone amp Fenris Headphone Systems 42 26th August 2015 02:01 AM
Power Amp Construction inspired by Curl, Slone and Pass circuitscc Solid State 11 21st May 2010 05:25 AM
b&w nautilus inspired speakers ceebmoj Multi-Way 5 17th November 2008 07:07 PM
My AB amp inspired by AlephX DarkOne Pass Labs 38 6th October 2005 12:03 PM
Checkout the Nelson Pass inspired GC hifimaker Chip Amps 0 25th January 2005 11:12 PM
