Strange behavior of my Threshold SL10 - diyAudio
Old 6th May 2012, 04:21 PM   #1
PKI is offline PKI  United States
PKI's Avatar
Default Strange behavior of my Threshold SL10
Is it ok that even if I plug only one input R or L you still have a sound from both channel on output? Does the ore go to mono mode if only there is only one input? Thanks!
Old 6th May 2012, 09:38 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
nope
that's not ok
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 6th May 2012, 10:11 PM   #3
PKI's Avatar
Thanks! But when I plug two channels and use balance signal goes from one channel to another. Any idea for further tests to find a problem? Can it be because of some old pots/switch?
Old 6th May 2012, 10:31 PM   #4
Zen Mod's Avatar
pics , please
Old 7th May 2012, 01:32 AM   #5
GaryB is offline GaryB  United States
I'd check the cables you're using as well. If one of them has a problem with the ground connection then you might find signal appearing in funny places as it tries to close the signal loop.
---Gary
Old 8th May 2012, 03:10 PM   #6
PKI's Avatar
Here are some photos(sorry for the quality, I will try to re take them).
I've double checked all the cables/connectors and external connections all good.
Old 8th May 2012, 04:57 PM   #7
Zen Mod's Avatar
everything looks OK , but it's hard to say from so grainy pictures ;
it's obviously recapped sometimes in the past ( Silmics aren't original caps , for sure )
probably mistake was made during re-assembling wires back to switches-connectors
try harder with pictures
Old 8th May 2012, 05:46 PM   #8
PKI's Avatar
I recapped it :-) So everything should be good there. I guess one thing was that I was having hard time assembling all these tiny rotary switches after I deoxited them. Do you thing you can shorten something in there so you have this "mono" problem while switching functions will be ok?
Old 8th May 2012, 06:07 PM   #9
Zen Mod's Avatar
well , something is obviously wrong
useful and easy procedure these days , while working on gadget, is to make plenty of digi pictures
it can save you later , if nothing else - time saving during assembly ( less thinking needed) can be substantial
dunno ... comparing your pictures with pictures of SL10 from Treshold broshures , it seems all wires on pcbs are in place , and I resume that you didn't desolder any of them
culprit can be either on switches or pots - take a good look for unintentional shorts
Old 8th May 2012, 06:11 PM   #10
PKI's Avatar
Thanks! I can try to solder in another attenuator. Will more resistance one decrease the gain (it is too much of it now. do not use more than two steps up)?
threshold sl10 intense-tavda Pass Labs 116 1st December 2013 09:52 PM
Threshold SL10 MK1 William Sadler Pass Labs 9 7th February 2012 11:23 AM
threshold sl10 donadi.tv Pass Labs 1 15th February 2008 04:25 PM
Threshold sl10 fs intense-tavda Swap Meet 3 23rd December 2006 11:22 AM
Copyright 1999-2017 diyAudio
