Strange behavior of my Threshold SL10 - Page 3 - diyAudio
Old 9th May 2012, 08:31 PM   #21
PKI is offline PKI  United States
PKI's Avatar
So what I have: output on th board and RCA -- R/L hot and ground zero resistance, shortened. Volume pot central tap R/L -- zero. The balance does not change anything.
Old 9th May 2012, 08:42 PM   #22
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
gns normal , but hots not
it seems culprit is in selector
pics , pretty please .
macro , external light , no flash
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th May 2012, 07:22 PM   #23
PKI's Avatar
So, I've checked cleaned and reassembled all the switches -- they look to be ok. It does not help :-(! It looks like this shortening between grnd ant hots (r,l,g -- all connected) occurs in the "end" inside or around this green box (coil) see photo attached. If you measure connectivity on rec outs -- everything good. What is inside this green coil can it cause the problem?Click the image to open in full size.
Old 20th May 2012, 07:34 PM   #24
Zen Mod's Avatar
that's simple and dumb relay
according to my schmtcs , that's muting relay - common for both channels
RLY1
Old 20th May 2012, 08:00 PM   #25
PKI's Avatar
So, can it be there, can find a replacement? It is shortened from the output rca's to after those two resistors on the photo.
Old 20th May 2012, 08:14 PM   #26
Zen Mod's Avatar
just desolder it and test without
be careful with powering up - first pre , then power amp
probably culprit isn't in relay itself , but in traces around/beneath
Old 20th May 2012, 09:13 PM   #27
PKI's Avatar
Thanks I'll do it. Maybe there is something wrong with it. The pre turns on with a big "pup" sound.
Old 20th May 2012, 11:45 PM   #28
PKI's Avatar
Yep, it was a relay. Removed it and have the problem gone, but sure need a replacement. Can you please suggest me a replacement which is available on market? Thanks!
P.s. I hate these switches in sl-10, how mr Pass could approve them for usage? :-)
Old 20th May 2012, 11:52 PM   #29
Zen Mod's Avatar
dunno situation on your market
pic with some measures will help
you can also search locally for Takamisawa relays
quality isn't critical - it's there just as mute part
Old 21st May 2012, 01:56 AM   #30
PKI's Avatar
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
(These are metric)
threshold sl10 intense-tavda Pass Labs 116 1st December 2013 09:52 PM
Threshold SL10 MK1 William Sadler Pass Labs 9 7th February 2012 11:23 AM
threshold sl10 donadi.tv Pass Labs 1 15th February 2008 04:25 PM
Threshold sl10 fs intense-tavda Swap Meet 3 23rd December 2006 11:22 AM
Copyright 1999-2017 diyAudio
