Strange behavior of my Threshold SL10 - Page 2 - diyAudio
Old 8th May 2012, 07:36 PM   #11
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
atten doesn't have influence on gain
I already wrote few times what's needed to decrease gain of SL10
if you can't find these posts , buzz and I'll repost sch and procedure
check resistance (with ohmmeter) between L&R hots prior and post selector
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 8th May 2012, 07:54 PM   #12
PKI is offline PKI  United States
PKI's Avatar
Ok, got it. Yep, of cause not gain wrong word, sorry. I will check resistance today. Another thing, I already bought a PCB of B1, cause I would like to replace the SL-10 with B1 and pearl 2, do you think I will "gain" :-) in sound quality compare to sl-10?
Old 8th May 2012, 08:07 PM   #13
Zen Mod's Avatar
regarding gain issue - look at attached schm - for 6db gain decrease - either double in value 750R or halve in value 18K2 (both marked red)
B1 vs. SL10 .......
do not underestimate old geezers
B1 is welcome in your system if your sources are capable to drive power amp directly , swing-wise
Old 8th May 2012, 08:21 PM   #14
PKI's Avatar
Originally Posted by Zen Mod View Post
regarding gain issue - look at attached schm - for 6db gain decrease either double in value 750R or halve in value 18K2 (both marked red)
B1 vs. SL10 .......
Thanks! Ok, I see for B1 vs sl-10 it is quite predictable, but what about phono stage of SL-10 vs Pearl 2? Have Mr. Pass and others improved it after ~30 years?
Old 8th May 2012, 08:27 PM   #15
Zen Mod's Avatar
Pearl is better
Old 9th May 2012, 02:26 AM   #16
GaryB is offline GaryB  United States
The schematic has a minor error compared to my SL10. The volume pot in my SL10 is 22K, not 10K. But your answer is still fine.
Another way of reducing the gain is to increase the value of the 1K resistor in series with the volume pot. Increasing it to ~12k will decrease gain by about 6db if your unit has a 10K pot. If your unit has a 22K pot then increasing the resistor to ~24K would drop the gain by 6db.
---Gary
Old 9th May 2012, 06:20 AM   #17
Zen Mod's Avatar
I prefer to decrease CLG of stage , not further weakening of signal ......... doing same thing as with pot on 8,5h
name of the game is - signal energy preservation , not convenience of full shaft rotation
Old 9th May 2012, 06:37 AM   #18
PKI's Avatar
So, I've checked resistance between hot R and L and it is zero(within the accuracy of my meter). Hm... From what should I start to find the reason -- desilder all the switches and attenuator and check them?
Old 9th May 2012, 06:50 AM   #19
Zen Mod's Avatar
where exactly you took measurements ?
Old 9th May 2012, 02:15 PM   #20
try the same with the balance a little offset.
threshold sl10 intense-tavda Pass Labs 116 1st December 2013 10:52 PM
Threshold SL10 MK1 William Sadler Pass Labs 9 7th February 2012 12:23 PM
threshold sl10 donadi.tv Pass Labs 1 15th February 2008 05:25 PM
Threshold sl10 fs intense-tavda Swap Meet 3 23rd December 2006 12:22 PM
Copyright 1999-2017 diyAudio
