My Pearl2 Built
My Pearl2 Built
Old 4th May 2012, 12:31 AM   #1
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
My Pearl2 Built
Default My Pearl2 Built
Hi. I completed my Pearl2 months ago but never took the time to post the complete set of pictures. It may inspire some of you guys
First the PCB, I did my own.
Old 4th May 2012, 12:45 AM   #2
Algar_emi's Avatar
My Pearl2 Built
Then the external power supply. I used a small hammond steel enclosure. I prefer steel for the supply for increase shielding. Everything is mounted point-to-point.
Old 4th May 2012, 12:49 AM   #3
Algar_emi's Avatar
My Pearl2 Built
The base of the case is a recycled switching supply case used in communication, very rigid. I used good quality parts, Mundorf main supply caps, Cardas connectors and wires for power, 6N single crystal/TFE wire for signal, AMP gold plated power connector, Vishay and PRP resistors, Wima, ROE caps, etc.
Old 4th May 2012, 12:52 AM   #4
Algar_emi's Avatar
My Pearl2 Built
And the case finish. To cover the sides [I] used small slide of wedge wood, with oil finish. The rest of the case, front, back and top were done by Front Panel Expert. Exquisite fit and finish.
Old 4th May 2012, 12:56 AM   #5
ra7 is offline ra7  United States
My Pearl2 Built
Sexy!
Tell us more about the diy pcb.
Old 4th May 2012, 01:15 AM   #6
turboyam is offline turboyam  Canada
I looooooooove it!
Old 4th May 2012, 02:58 AM   #7
6L6 is online now 6L6  United States
6L6's Avatar
My Pearl2 Built
Wow! Looks great!
Where did you get the R-core transformer?
Old 4th May 2012, 01:51 PM   #8
PierreQuiRoule is offline PierreQuiRoule  Canada
PierreQuiRoule's Avatar
My Pearl2 Built
Truly inspirational. Thank you!
Old 4th May 2012, 04:18 PM   #9
Dennis Hui is offline Dennis Hui  Canada
My Pearl2 Built
Wonderful! Always great to see your work.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 4th May 2012, 05:06 PM   #10
Algar_emi's Avatar
My Pearl2 Built
Thanks for your comments.
RA7, I did a few years back a two parts article on how to make your own PCB.
Files are kind of big. Send me a private email and I'll send you a copy.
I used to solder plate my pcb, now I used my ''special'' sprayed protection film to protect the copper. What is great about this stuff that is burn away when you solder the part. No need for a solder mask. For small smd parts, I install them first, then spray the stuff, finally I solder the bigger through hole parts.
6L6, I got the R-Core transformer from DIYclub, part R26-75, paid U$19.25 + shipping at the time...
My Pearl2 BuiltHide this!Advertise here!
Who has built their own? markp Solid State 43 3rd August 2014 10:10 AM
Hi! And I built one too... The RB Chip Amps 4 13th March 2009 10:12 AM
What have I built? george a Pass Labs 2 13th January 2005 09:47 PM
has anyone built these? spoggles Multi-Way 2 3rd June 2004 06:50 PM
