#71 |
guido,
One solution is to put 1 more relay used as a "Mute relay" it makes a short cut at the output during the volume adjust, and opens a few millisecond after the volume change... Regards. Alain. |
#72 |
If you can spare some gain you can also put a fixed L-pad after the last relay. I have a 2dB L-pad in my setup and can hardly notice any clikcs.
Sven Sødem |
#73 |
Help... I got confused along the way!
If I was using x-pro's circuit between a pre-amp and amplifier, do I put a 10K resistor in parallel with the amplifier input? Or, if I had an amplifier with a 10k input impedance, do I simply connect the last attenuation stage of the circuit to the amplifier (and not have the 10k resistor)? In other words: if I have a 10k input impedance amplifier, is that the 10k load on the right hand side of x-pro's diagram? Thanks! |
#74 | |
Cheers x-pro |
#75 |
Been lurking for a long time here... Fist, a great thank you to X-pro for posting this attenuator topology. I have used another topology for years, but it has never worked that well. This weekend I tried this one, and it works great. I changed it to 1,25dB/step and 50kOhms, and produced a spreadsheet to calculate the values, based on the L-pad formulas in Dickasons Loudspeaker Cookbook. Re the clicks, I use dual coil latching relays (one coil for 'on' and one for 'off') and delay the 'on' pulse. The relays need to open before the others close. This works pretty well. If you use a µC-based control, first switch the relays that are turning off, then the ones that are turning on. Then it will work without dual coil relays. I attach the spread sheetI did for this, it allows you to choose the step attenuation, attenuator impedance and number of bits. You can also try standard values and see how they work out in practice. Regards, Bjørn |
#76 |
Seems I can't attach anything yet, so I've uploaded the spread sheet to http://www.geocities.com/la1zka/diverse/Attenuator.zip
Bjørn |
| A twisted tale about a logarithmic relay attenuator | Russ White | Parts | 663 | 1st July 2011 10:23 PM |
| Yet another relay attenuator | jwb | Solid State | 34 | 21st July 2010 08:17 AM |
| Constant Voltage Impedance Measurement | Gcollier | Multi-Way | 7 | 29th June 2006 10:54 PM |
| Constant input impedance polarity switcher | Steven | Solid State | 13 | 15th October 2003 02:16 AM |
| T-link attenuator with constant impedance | peranders | Parts | 4 | 7th October 2003 01:19 PM |
| Page generated in 0.11100 seconds (70.12% PHP - 29.88% MySQL) with 11 queries |
