#21 |
Ya, I just realized that myself, how silly of me. It's the same for my circuit.
_______ Brian |
#22 |
It was mentioned on another link to this attenuator that it was patented. Whats the US patent #?
_______ Brian |
#23 |
Ok, I've adapted this pot to simulate a true single-channel pot. Now, any output load & any input load is usable. Also, a volume of 0 is now - (infinity) db. 127 will be -0.000000 db.
I've boxed the DPDT relays. The top half is wired to the n-o (normally open) side, and the bottom is on the n-c (normally closed). I know it's double the resistors & double the switches, but, I want an authentic emulation of a real logarithmic pot. Will it emulate correctly?
_______ Brian |
#24 | |
. I did publish it in 2002 to prevent someone else from doing it as it is in a public domain now. The question was about your design not mine - I think it was something on patent pending on one of your diagrams?x-pro. |
#25 | |
. I used only ONE switchover relay contact where that circuit uses two, as would be required for T or P -attenuators as well.x-pro. |
#26 | |
x-pro |
#27 | |
. However it would make sense (and I've done it in production) to wire the relays in "max" attenuation position when there is no power to the relays (opposite to what is shown on the diagram from the magazine). x-pro |
#28 |
There is a little problem with this circuit, the input impedance is really 10kOhms (if there is a 10k on the output too), but output impedance is changing with the actual relay-settings !!! So it's better to use pi or T-network, if you don't want to compute values of resistors and parallel or serial combinations, you can read something about it and use applet from my page, but it's only in Czech language. Have a nice day with a dictionary
![]() http://dzin.hi-end.org/utlum.htm Dzin |
#29 |
Yeah, I see, it will be better to minimize the relay contacts in signal path!
best regards Kay |
#30 |
Hi Dzin,
>Czech language. Have a nice day with a dictionary I like to read, but I don't like a dictionary ![]() The T-switch is the the Elektor circuit, see link above.
best regards Kay |
| A twisted tale about a logarithmic relay attenuator | Russ White | Parts | 663 | 1st July 2011 10:23 PM |
| Yet another relay attenuator | jwb | Solid State | 34 | 21st July 2010 08:17 AM |
| Constant Voltage Impedance Measurement | Gcollier | Multi-Way | 7 | 29th June 2006 10:54 PM |
| Constant input impedance polarity switcher | Steven | Solid State | 13 | 15th October 2003 02:16 AM |
| T-link attenuator with constant impedance | peranders | Parts | 4 | 7th October 2003 01:19 PM |
| Page generated in 0.14912 seconds (82.69% PHP - 17.31% MySQL) with 11 queries |
