#31 | ||
There can however be a theoretical basis to decide that one topology is objectively better than another. Nelson for instance tells us in the Aleph manuals that he believes that using few gain stages is better than using a lot of gain stages. Quote:
#32 | |
#33 | |
![]() It is funny though that this is an example where there really is an "objective best". Do not throw away your bits!
#34 | |
If you attenuate past 60-80 db then sure you will introduce high frequency noise compared to original signal, but then there won't be a lot of signal left so you probably wouldn't hear it anyway
#35 | |
Aleph 30 manual attached
#36 |
#37 |
#38 |
The Pass Aleph 30 is unique in a number of ways:
Most amplifiers on the market have between five and seven gain stages in series between the input and the output. The Aleph 30 has but two, and enjoys a very direct path from input to output, further enhancing the purity of the circuit and the resulting sound. Nelson mentioned the Aleph 30 uniqueness: Most amps on the market are class-B, the Aleph 30 is class-A ![]() It's an amplifier by Lazy Cat. Only two stages but you can get above 50W easily, and current feedback. |
| Possible to use tweeter L-pad (attenuation circuit) to add resistance eg. 4 to 8 ohm | chucky12 | Multi-Way | 13 | 13th October 2011 10:33 PM |
| Aleph P Attenuation Circuit | amo | Pass Labs | 13 | 6th October 2011 07:20 PM |
| Driver Attenuation Circuit what watt resistor to use? | noahtheviking | Multi-Way | 2 | 13th April 2011 05:33 AM |
| Attenuation circuit findings Fe208e sigma | adamt | Full Range | 0 | 22nd June 2010 02:20 AM |
| How much less from the ideal??? | Leolabs | Solid State | 0 | 18th May 2007 02:54 AM |
