#21 | |
My background is mathematics and IT, not engineering. I am used to modelling and designing first (and remodelling and redesigning second, and third and fourth and fifth and ... you get my point ), with building much, much later. I always thought that good sound was the result of superior design. What the last year, reading diyaudio, has taught me is that good sound is much more about part selection/interaction and optimising a design for those parts than I had thought. It has also taught me never to give an example when I ask a hypothetical question ![]() Which system gain article did you have in mind? |
#22 |
Maybe the mods should prohibit use of words like 'best', 'ideal' (except in a theoretical sense), 'ultimate' etc. from the forum? 'Best' and 'ideal' always mean that an optimisation problem must be be posed and solved, which means that detailed goodness criteria must be stated (but they never are). 'Ultimate' means impossible to better, which is a silly idea for anything made by humans.
#23 |
At 0dB you can use all 16 (or 24 or however many you have) bits to send the signal. If you attenuate, you need some of those bits to send a lot of zeroes. You cannot use those bits for the actual signal. Information will thus be lost if you use digital attenuation.
#24 | |
#25 |
On the front page of diyaudio under articles.
It might do you good to read all of them, so that you then know where to go before asking ambiguous questions. BTW, I get the impression that you think you are at a disadvantage in not being an electronics trained Member. You will find if you look that the vast majority here are non electronics and non electrical. They are here because they have electronics as a hobby and as a result they are self taught. |
#26 |
I agree with DF, design and implementation leads to good performing product.
#27 | |
A good sound is a result of a complete system design from source to speaker. They are interdependent. We need to know IT in digital processing. We need to know mechanic and acoustics in speaker design and worse we need to know psychology and biology ![]() Because audio system is usually designed partially, it makes part selection/interaction and optimization become more critical. You may have the "best" amplifier design and the "best" speaker design but if your speaker doesn't want to cooperate with the amp, then you will not get the "best" sound. |
#28 |
#29 |
My first career was in IT, and the language of serious audio is not that different; both are branches of engineering. As I said, 'best' should make you think 'optimisation problem' which then leads to 'criteria?'.
#30 | |
| Possible to use tweeter L-pad (attenuation circuit) to add resistance eg. 4 to 8 ohm | chucky12 | Multi-Way | 13 | 13th October 2011 10:33 PM |
| Aleph P Attenuation Circuit | amo | Pass Labs | 13 | 6th October 2011 07:20 PM |
| Driver Attenuation Circuit what watt resistor to use? | noahtheviking | Multi-Way | 2 | 13th April 2011 05:33 AM |
| Attenuation circuit findings Fe208e sigma | adamt | Full Range | 0 | 22nd June 2010 02:20 AM |
| How much less from the ideal??? | Leolabs | Solid State | 0 | 18th May 2007 02:54 AM |
