diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Stuck on F5 Build power-up... (http://www.diyaudio.com/forums/pass-labs/211722-stuck-f5-build-power.html)
hartze11 28th April 2012 08:17 PM
I'm stuck powering up the F5 (2.0 from cviller)....
I get no heat, and zero volts across R11/R12. Turning the pots has no effect on anything.
If I had to guess, Q1 and Q2 are doing nothing. I see about 30-40 mV across R1/R2.
I have replaced them (Q1/Q2), but from the same stock (yes, I bought crap from China via Ebay).
Any thoughts? Thanks. ~Dave
Zen Mod 28th April 2012 09:19 PM
pics , parts origin info etc.
6L6 28th April 2012 09:21 PM
Ebay jfets are most likely fake.
Are you sure turning the pots has no effect? They sometimes take a bunch of turns to do anything.
Are your V+ GND and V- measuring properly at the amplifier boards?
And very important, please post some photos.
Thanks!
SirByrd 28th April 2012 09:47 PM
Make sure your power supply is working properly, and that you have all jumpers installed and soldered in on the boards (I don't know if there are any on the cviller boards)
Then, go over each of your boards and make sure everything is in the right place.
AndrewT 29th April 2012 10:38 AM
Have you measured the Idss of the jFETs?
hartze11 29th April 2012 01:40 PM
Well, it looks like a 2.2K resistor got installed instead of a 22K for R21/R22.
I will build a new board (using new transistors) and give that a try...
6L6 29th April 2012 02:18 PM
Measure the Idss of your current Jfets (as Andrew suggested) if you have a chance to take them out - if they are genuine, they are pretty durable.
Make the changes to your existing board -- save yourself a bit of work. You will probably be able to get this one working.
Edit - One last question, what schematic are you using? The version with P3? If so, is it on one side of it's range or approximately centered?
Check your PMs.
hartze11 29th April 2012 02:56 PM
Originally Posted by 6L6 (http://www.diyaudio.com/forums/pass-labs/211722-stuck-f5-build-power-post3005341.html#post3005341)
I have a couple new ones from the Chinese source... I can measure those.
I see that 2sk170s are still available in quantity for Mouser (and I assume they are the original Toshiba). Is there a source for the 2sj74?
Check your PMs.
This is the latest version of the PCB that I can find, but it contains components for other versions: http://www.diyaudio.com/forums/blogs...e_forguide.png
Is there a better one? The boards are v2.0 2010-10-23 (standard F5).
Thanks!
6L6 29th April 2012 03:21 PM
Off the top of my head I know that you can get 2SJ74s (and K170s) from member " h_a ", and also from the AMB.org site in his store. There are probably other sources as well, I just can't think of any right now.
Your schematic link is really small... and I wonder if the schematic has different part numbers than the original schematic... Do you have a bigger image of it?
Bksabath 29th April 2012 03:23 PM
What voltagge if any at gates of mosfets?
maybe resistor pot combination is running out of steam as it does happens same time and resistor value need to be changed
Is voltagge changing as you turn the pots?
Mosfets need 3.5 to over 4 V to start conducting so ....
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
